Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
wmake error for a new viscosity model
Old   October 27, 2009, 11:12
Default wmake error for a new viscosity model
ICL
Ali Sh
ICL is on a distinguished road
Hey guyz,
I got the following errors when I tried to compile (wmake) a viscosity model. Everything was fine before with the same change. I don`t really know why I got these errors now:
incompressible]$ wmake
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I.. -I/home/ahajisha/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/ahajisha/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/ahajisha/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/transportModel.o Make/linux64GccDPOpt/singlePhaseTransportModel.o Make/linux64GccDPOpt/viscosityModel.o Make/linux64GccDPOpt/newViscosityModel.o Make/linux64GccDPOpt/Roelands.o Make/linux64GccDPOpt/EyringRoelands.o Make/linux64GccDPOpt/Doolittle.o Make/linux64GccDPOpt/Newtonian.o -L/home/ahajisha/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \
-lOpenFOAM -liberty -ldl -lm -o OpenFOAM.out
/usr/lib/../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
Make/linux64GccDPOpt/viscosityModel.o: In function `Foam::fvPatchField<Foam::SymmTensor<double> >::type() const':
viscosityModel.C.text._ZNK4Foam12fvPatchFieldINS _10SymmTensorIdEEE4typeEv[Foam::fvPatchField<Foam::SymmTensor<double> >::type() const]+0x3): undefined reference to `Foam::fvPatchField<Foam::SymmTensor<double> >::typeName'
Make/linux64GccDPOpt/viscosityModel.o: In function `Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::type() const':
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
I would be very grateful if anyone can lead me to the source of the error.
Thanks alot,
Ali
ICL is offline   Reply With Quote
Old   October 27, 2009, 12:01
Mattijs Janssens
Probably you want to build a library, not an executable. Use 'wmake libso' to build a library. This is not a bug.
Old   October 27, 2009, 12:05
ICL
Ali Sh
I compiled the new viscosity model with wmake and I used to compile it with wmake every time I changed it. This time I only changed a constant value in it and got the above-mentioned error using wmake! I don`t know what is the reason...
Old   October 27, 2009, 12:07
ICL
Ali Sh
I typed wmake in src/transportModels/incompressible by the way. As I mentioned it was fine using wmake for that before.
Old   October 30, 2009, 06:44
Default Correction
ICL
Ali Sh
First of all, that was not a bug ( Sorry for that)
Use of wmake is possible for executable files such as Solvers. There is a library specified to transportmodels/incompressible and that should be updated using wmake libso incompressible in src/transportmodels directory.
Old   March 2, 2017, 10:30
Emery
TemC is on a distinguished road
Hi foamers,
I'am working with simpleFoam, and I want to implement a new Herschel-Bulkley model. I have already done all the major steps and modifications required.
Now when I try to execute the command "./Allwmake" in "src/transportModels/", I got the message depicted in the attachment. And even when I use the command "wmake libso incompressible" suggested on this thread, I still have this message. Does anybody know what it may be linked to?
I hope that you will find a couple of minutes to give me a reply. Any contribution will be well aprreciated.
Thanks in advance for your time, and have a nice week.
Regards.
TemC is offline   Reply With Quote
Old   March 2, 2017, 11:52
floquation's Avatar
Kevin van As
floquation will become famous soon enough
My French is a little rusty, but a few seconds are enough to find the answer:
It says "impossible to create the repository ... permission denied".
In other words, you do not have writing rights in that directory, which makes a lot of sense as it is the "/opt" directory.
You need to either compile using the super-user account [you probably do not want to do this, especially as there is no reason to modify the original OpenFoam source code], or you should compile your modified code in a directory in which you have writing rights. I usually compile my own modifications in ${FOAM_RUN}/../applications or ${FOAM_RUN}/../libraries.
It'd be a good idea to put your executable in $FOAM_USER_APPBIN, instead $FOAM_APPBIN, as it is a user modification.
floquation is offline   Reply With Quote
Old   March 3, 2017, 03:30
Emery
Good morning Sir,
Thank you very much for your advices, I will take them into account.
Regards.
compile, error, openfoam, wmake
Implementing new viscosity model prjohnston OpenFOAM Running, Solving & CFD 6 July 3, 2015 04:26
Yielding viscosity for Herschel Bulkley model Godwin FLUENT 1 December 12, 2011 05:42
Power Law Viscosity Model cpplabs OpenFOAM Running, Solving & CFD 1 February 13, 2008 08:09
Casson Viscosity model as one user define function Zahra Rahmdel FLUENT 0 November 6, 2004 05:53
