Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
moveDynamicMesh broken ?
Old   November 11, 2009, 08:57
Default moveDynamicMesh broken ?
Pierre-Olivier Dallaire
podallaire is on a distinguished road
tried to run moveDynamicMesh today and it seems that it's now broken, happened last month because this behaviour was not observed back in September. As an example, running tutorial SnakeRiverCanyon will give this :
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementSBRStress
--> FOAM FATAL IO ERROR:
wrong token type - expected word found on line 57 the label -1
file: SnakeRiverCanyon/0/pointDisplacement::wedgePlane at line 57.
From function operator>>(Istream&, word&)
in file primitives/strings/word/wordIO.C at line 77.
FOAM exiting
Any idea ?
Regards,
PO
podallaire is offline   Reply With Quote
Old   November 11, 2009, 10:03
Mattijs Janssens
mattijs is on a distinguished road
Thanks for reporting. Was bug in reading the optional wedge axis. Fixed in 1.6.x.
mattijs is offline   Reply With Quote
Old   November 11, 2009, 13:44
Thanks, tested and it worked
"spanwise line broken ?" liang Fidelity CFD 1 March 13, 2010 01:06
Help for Broken dam problem JSS Main CFD Forum 2 November 20, 2009 16:42
SOLA-VOF and Broken Dam Problem SOLA-VOF and Broken Dam problem Main CFD Forum 6 November 20, 2009 16:27
broken contour at 1920*1200 monitor kris FLUENT 1 April 19, 2007 04:00
[Ref. Vel. in Broken dam prob.] Beginner Main CFD Forum 1 June 20, 2001 11:28
