November 26, 2009, 13:55 |
A bug in using dynamic LES models
zakk
I m trying to use the dynamic LES models in the version 1.6 . Among the various models, only Smagorinsky and oneEqEddy model. The others are giving that error when I m running : Selecting incompressible transport model Newtonian Selecting turbulence model type LESModel Selecting LES turbulence model dynSmagorinsky keyword filter is undefined in dictionary "" file: From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 388. FOAM exiting |
November 26, 2009, 15:35 |
Alberto Passalacqua
Rep Power: 36 |
I can confirm this behaviour.
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
November 27, 2009, 03:48 |
Rep Power: 22 |
That is true, the choice of filter does not currently have a default and to use the dynamic models you will need to specify the filter you want to use. Do you think the
filter should have a default? If so which one do you think it should default to? H |
November 27, 2009, 15:43 |
#4 | |
Alberto Passalacqua
Rep Power: 36 |
Hi Henry,
it used to default to "simple" filter in previous versions of OF, but probably a slightly different error message could also do the job. Something along the lines of Quote:
Thanks. Best,
December 8, 2009, 09:40 |
Rep Power: 22 |
I have pushed a development of "dictionary" into OpenFOAM-1.6.x which generates better warning and error messages. I hope that for this case it will make clearer what entries need to be added to the dynSmagorinskyCoeffs dictionary.
H |
December 8, 2009, 12:02 |
Alberto Passalacqua
Rep Power: 36 |
Thanks!
Best,
December 8, 2009, 16:34 |
zakk
Thank you
Regards |
LES Dynamic models details | lakeat | OpenFOAM Programming & Development | 10 | May 19, 2011 07:46 |
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow | harishg | OpenFOAM Bugs | 5 | December 2, 2008 18:18 |
Failed dimensional check with dynamic LES models | alberto | OpenFOAM Bugs | 9 | September 5, 2007 22:57 |
LES dynamic models fail dimensional check | alberto | OpenFOAM Running, Solving & CFD | 0 | June 11, 2007 13:23 |
Nan on LES dynamic models | sampaio | OpenFOAM Running, Solving & CFD | 10 | March 8, 2005 15:44 |
