Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in turbulentHeatFluxTemperatureFvPatchScalarField; OF 1.6.x
Old   February 1, 2010, 08:40
Default Bug in turbulentHeatFluxTemperatureFvPatchScalarField; OF 1.6.x
Oleksiy Kurenkov
evrikon is on a distinguished road
Send a message via Skype™ to evrikon
Hi forum,
in OpenFoam 1.6.x the boundary condition which represents a constant heat flux through the boundary does not work for incompressible cases like buoyantBoussinesqSimpleFoam. To see the bug please have a look into
/src/turbulenceModels/incompressible/turbulentHeatFluxTemperatureFvPatchScalarField.C
:line 160
You can see:
const scalarField& Cpp =
patch().lookupPatchField<volScalarField, scalar>(CpName_);
This is not correct because an incompressible solver does not have any information about Cp.
Here is my bugfix:
void turbulentHeatFluxTemperatureFvPatchScalarField::up dateCoeffs()
if (updated())
return;
const RASModel& rasModel = db().lookupObject<RASModel>("RASProperties");
const scalarField alphaEffp =
patch().lookupPatchField<volScalarField, scalar>(alphaEffName_);
// const scalarField& Cpp =
// patch().lookupPatchField<volScalarField, scalar>(CpName_);
transportModel& laminarTransport = rasModel.transport();
dimensionedScalar Cp(laminarTransport.lookup("Cp"));
gradient() = q_/(Cp.value()*alphaEffp);
fixedGradientFvPatchScalarField::updateCoeffs();
Further I specified Cp by adding one line into readTransportProperties.H for solver buoyantBoussinesqSimpleFoam:
//Bug fix OLK: Cp is needed for fixedHeatFlux boundary condition
// Heat capacity
For other incompressible solvers with heat transfer it should be done too.
Now I can use the new boundary condition turbulentHeatFluxTemperature for both compressible and incompressible cases.
Cheers, Oleksiy
Cheers, Oleksiy
evrikon is offline   Reply With Quote
Old   July 2, 2010, 05:23
Robert
rob3rt is on a distinguished road
Hello Evrikon,
I had this error while trying to compile your bugfix.
derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C:1 59: error: ‘transportModel’ was not declared in this scope
derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C:1 59: error: ‘laminarTransport’ was not declared in this scope
derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C:1 59: error: ‘rasModel’ was not declared in this scope
derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.C:1 62: error: ‘Cpp’ was not declared in this scope
What should I declare to make this working?
And
another question is: what is difference between turbulentHeatFluxTemperature (without rho) and wallHeatFlux (http://openfoamwiki.net/index.php/Contrib_wallHeatFlux)?
I think both can be used for incompressible cases, right?
Thanks very much for your time.
Kind Regards,
Robert.
rob3rt is offline   Reply With Quote
Old   September 7, 2010, 07:31
Oleksiy Kurenkov
Dear Robert,
I implemented this bug fix directly in OpenFoam 1.6.x. I changed the boundary condition in turbulentHeatFluxFvPatchField.C as described above and recompiled the whole turbulenceModels staff. It takes only a few minutes. If you try to do that, please do a backup of turbulenceModels directory before!
I assume you simply miss the corresponding libraries. Do you try to define this boundary condition as your own library? Then you do need to look into your Make/files and Make/Options.
Cheers, Oleksiy
Old   September 9, 2010, 04:39
cgoniva is on a distinguished road
Dear Oleksiy,
Shouldn't you add rho to the equation:
"gradient() = q_/(Cp.value()*alphaEffp*rho0); "
as this is done here (http://openfoamwiki.net/index.php/Contrib_wallHeatFlux) ???
This rho should be read from dictionary as you did for Cp:
"dimensionedScalar rho0(laminarTransport.lookup("rho0")); "
Cheers,
Chris
cgoniva is offline   Reply With Quote
Old   September 9, 2010, 04:52
oh... some mistake, it should be:
"gradient() = q_/(Cp.value()*alphaEffp*rho0.value()); "
Cheers, Chris
Old   September 27, 2010, 08:52
Oleksiy Kurenkov
No, I only speak about the incompressible case where no rho is present in OpenFoam. Therefore the gradient is not divided by rho. For compressible cases it should be divided.
Cheers, Oleksiy
Error occurs when compiling OpenFoam 1.6.x with Icc fs82 OpenFOAM Bugs 5 January 20, 2010 03:08
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 08:15
Bug in Meshing Parameters menu Spacing1 (1e+10) Karna ANSYS Meshing & Geometry 1 October 12, 2009 14:38
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 10:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 10:22
