Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Missing division by dt in COxidationMurphyShaddix
Old   May 17, 2010, 15:43
Default Missing division by dt in COxidationMurphyShaddix
omarzouk is on a distinguished road
In the Murphy-Shaddix submodel for char oxidation:
src/lagrangian/coalCombustion/submodels/surfaceReactionModel/COxidationMurphyShaddix/COxidationMurphyShaddix.C
In the statement:
const scalar qVol = sum(dMassVolatile)/(WVol_*Ap);
This is supposed to be a molar rate [kmol/m^2/s], so it should be divided by dt.
omarzouk is offline   Reply With Quote
Old   May 17, 2010, 15:59
Default Calculating heat-of-reaction in submodel: COxidationMurphyShaddix
In the char-oxidation submodels under:
OpenFOAM-1.6/src/lagrangian/coalCombustion/submodels/surfaceReactionModel/
for: C(s) + O2(g) => CO2(g)
[COxidationDiffusionLimitedRate] and [COxidationKineticDiffusionLimitedRate] calculate the heat of reaction based on the enthalpies of formation (i.e., chemical specific enthalpy), whereas [COxidationMurphyShaddix] calculates it based on the total (i.e., chemical plus sensible specific enthalpy) specific enthalpies.
Old   May 18, 2010, 12:22
henry is on a distinguished road
Are you running OpenFOAM-1.6.x? It appears that the code snippet you posted is out of date and the latest version is in our git repository.
H
henry is offline   Reply With Quote
Old   May 18, 2010, 15:19
Thanks for the reply.
I am running 1.6. However, I see that you advise me to switch to 1.6-x which seems to have addressed several implementation mistakes in 1.6.
Thanks.
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
Missing output files stefanke OpenFOAM Running, Solving & CFD 4 September 8, 2006 04:51
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 00:34
about the missing component by setting BC. Kim FLUENT 1 May 28, 2004 11:33
