Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
MRFSimpleFoam with cyclicGgi in parallel
Like Tree1Likes
  • 1 Post By hannes
Old   April 7, 2009, 03:48
Default MRFSimpleFoam with cyclicGgi in parallel
Hannes Kröger
hannes is on a distinguished road
Hello to everyone,
I encounter a problem when I try to use the the cyclicGgi in MRFSimpleFoam in a parallel run (using the latest OF-1.5-dev from SVN).
As I have found out, the new GGI-Implementation requires the two cyclic patches to be in two different zones whereas the MRF solver requires them to be in the rotor zone. So, I have defined the two cyclic face zones in the constant/MRFZones dict to be rotating as well (symmm and symmp are the cyclic patch face zones, the corresponding cellZones are empty):
3
rotor
patches (PROP);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 58.6431;
symmm
patches ();
symmp
patches ();
This seems to work in serial, but when I try to run the case in parallel, the following error occurs:
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0591515, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0426731, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0704887, No Iterations 2
[1]
[1]
[1] given label greater than the number of geometric faces
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam:olyBoundaryMesh::whichPatch(int) const in "/home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::MRFZone::relativeFlux(Foam::GeometricField<d ouble, Foam::fvsPatchField, Foam::surfaceMesh>&) const in "/home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::MRFZones::relativeFlux(Foam::GeometricField< double, Foam::fvsPatchField, Foam::surfaceMesh>&) const in "/home/kroegeh/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 main in "/home/kroegeh/OpenFOAM/kroegeh-1.5-dev/applications/bin/linux64GccDPOpt/MRFSimpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/kroegeh/OpenFOAM/kroegeh-1.5-dev/applications/bin/linux64GccDPOpt/MRFSimpleFoam"
It seems that the MRFZones-Code tries to access some faces that are not present. Is there a nice and elegant way to fix that?
Best regards, Hannes
hannes is offline   Reply With Quote
Old   April 9, 2009, 04:55
Hannes Kröger
For those who are interested: I have fixed it by inserting the marked statement below in MRFZones.C (in function "relativeFlux"):
forAll(faces, i)
label facei = faces;
if (facei < mesh_.nInternalFaces())
phi[facei] -= (Omega ^ (Cf[facei] - origin)) & Sf[facei];
[i] else if (facei < mesh_.nFaces())
label patchi = mesh_.boundaryMesh().whichPatch(facei);
label patchFacei = mesh_.boundaryMesh()[patchi].whichFace(facei);
phi.boundaryField()[patchi][patchFacei] -=
(Omega ^ (Cf.boundaryField()[patchi][patchFacei] - origin))
& Sf.boundaryField()[patchi][patchFacei];
mm.abdollahzadeh likes this.
Old   April 14, 2009, 03:51
BastiL
bastil is on a distinguished road
Hannes,
take into account using the MRF from 1.5.x combined with ggi from 1.5-dev. The latest MRF can use cellZones without Facezones so you can form a cellzone for your mrf and a faceZone for the ggi.
Regards.
bastil is offline   Reply With Quote
Old   April 30, 2009, 06:49
Ravi
raavis is on a distinguished road
Hanes
I am trying to setup a MRF simulaton with ggi. Will it be possible for you to send me your system dictionaries, constant/dictionaries, boundary file and 0/files?
Thanks
raavis is offline   Reply With Quote
Old   May 1, 2009, 04:02
Hrvoje Jasak
Fixed - thank you for the bug fix. Apologies - there may be a few more problems like this because the mesh is now a bit more complex.
Hrv
Hrvoje Jasak
Old   April 29, 2010, 08:52
Timo K.
timo_IHS is on a distinguished road
Hello everybody,
I also want to run MRFSimpleFoam with cyclicGgi (latest OF-1.5-dev version).
Running this job in parallel doesn't work, a single run works.
Is there a mistake in my setup or is it a generell problem to run MRF with cyclicGgi in parallel?
Thanks in advance
Timo
timo_IHS is offline   Reply With Quote
Old   April 29, 2010, 11:21
BastiL
Parallel run should work. Without knowing you setup I would suspect it is more likely to have an error in this than a problem with Paralleisation. How doues your setup look like? How did you decompose your case?
Regards.
Old   April 29, 2010, 12:50
Timo K.
The steps of my setup are:
I. the "makeMesh" file for the setup
####for MRF:
cellSet ###choose all cells of rotor
setsToZones -noFlipMap
cp system/faceSetDict_rotorFaces system/faceSetDict
faceSet ###choose all faces of set rotor
cp system/faceSetDict_delInlet system/faceSetDict
faceSet ###delete faces of patch inlet
cp system/faceSetDict_delOutlet system/faceSetDict
faceSet ###delete faces of patch outlet
####for cyclicGgi:
cp system/faceSetDict_per1 system/faceSetDict
faceSet ###create face-zone per1_zone
cp system/faceSetDict_per2 system/faceSetDict
faceSet ###create face-zone per2_zone
II: my constant/MRFzones:
1
rotor
patches (hub per1 per2 shroud blade);
omega omega [0 0 -1 0 0 0 0] 100.81;
III: my system/decomposeParDict:
numberOfSubdomains 2;
method metis;
globalFaceZones ( per1_zone per2_zone );
metisCoeffs
processorWeights
1 1
Btw: I checked one setup possibility, I want to tell (single run):
if I delete the periodic faces of my set rotor (I), the results at the ggi are nonsens (velocity and pressure profile)
If you need some more info, let me know!
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
