Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
foam-3.1 and openmpi 1.8.1
Old   March 4, 2015, 06:49
Default foam-3.1 and openmpi 1.8.1
Pekka is on a distinguished road
I faced performance problem with system mpi (rhel6.6). A mpi version is 1.8.1 and latest source of the foam 3.1 is used. If on the same computer is running a one case everything works fine and performance is better than mpi 1.6.5. Performance dropping dramatically if I put other case to run by parallel. Looking at cpu load by "top" %CPU is only 50% and if the third case is put to running CPU load drop to 33.3%. So, from some reason cpus load is scaled by number of running task. This not happen by older mpi version.
Is it foam or mpi bug? or can it solve by some parameters?
Thanks
BR/Pekka
Pekka is offline   Reply With Quote
[OpenFOAM.org] mpirun not working in paralleö with OpenMPI zordiack OpenFOAM Installation 15 October 5, 2017 21:45
openmpi and "executable not found" bgoeppner OpenFOAM 1 April 1, 2010 07:51
HOW TO RUN FOAM WITH MPICH waynezw0618 OpenFOAM Running, Solving & CFD 5 May 13, 2009 08:21
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
