Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OF1.7: coalChemistryFoam/simplifiedSiwek error
Old   July 7, 2010, 20:11
Default OF1.7: coalChemistryFoam/simplifiedSiwek error
Leosding
leosding is on a distinguished road
As discussed in post "Patches for OpenFOAM 1.7 on MacOS X", the case of coalChemistryFoam/simplifiedSiwek error on Mac and Linux, log reads,
Courant Number mean: 0.1533929535 max: 0.6093346791
deltaT = 0.0005
Time = 0.252
Cloud: coalCloud1
Total number of parcels added = 27
Total mass introduced = 0.0001
Current number of parcels = 27
Current mass in system = 7.634816181e-05
Mass transfer phase change = 2.487806921e-06
Mass transfer devolatilisation = 1.096268892e-05
Mass transfer surface reaction = 1.020134234e-05
Cloud: limestoneCloud1
Total number of parcels added = 18
Current number of parcels = 18
Current mass in system = 0.0001
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.06843280288, Final residual = 5.521803873e-06, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 0.08299776218, Final residual = 6.610758425e-07, No Iterations 4
DILUPBiCG: Solving for O2, Initial residual = 0.02991408207, Final residual = 2.316092842e-07, No Iterations 4
DILUPBiCG: Solving for CH4, Initial residual = 0.02443785456, Final residual = 2.649269485e-07, No Iterations 4
DILUPBiCG: Solving for H2, Initial residual = 0.0315238668, Final residual = 3.822091915e-07, No Iterations 4
DILUPBiCG: Solving for CO2, Initial residual = 0.02938438982, Final residual = 4.003208991e-07, No Iterations 4
DILUPBiCG: Solving for H2O, Initial residual = 0.03523143241, Final residual = 1.795963946e-08, No Iterations 5
DILUPBiCG: Solving for hs, Initial residual = 0.04197246509, Final residual = 5.114508673e-07, No Iterations 4
--> FOAM FATAL ERROR:
attempt to use janafThermo<equationOfState> out of temperature range 0 -> 5000; T = -461.698
From function janafThermo<equationOfState>::checkT(const scalar T) const
in file /Users/dingsudong/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63.
FOAM aborting
check it.
Regards,
Leo
leosding is offline   Reply With Quote
Old   July 18, 2010, 05:25
Leosding
The same errors occurs in Linux and Mac ports.
nobody response it?
Leo
Old   July 19, 2010, 09:25
Andrew Heather
heather is on a distinguished road
Thanks for reporting - we have updated the tutorial in 1.7.x
heather is offline   Reply With Quote
Old   September 29, 2010, 11:54
N. A.
N. A. is on a distinguished road
Heloo Andrew and folks,
This in relation to the error that is reported by Leo. I assume that Andrew has updated the tutorial and there is no error.
I am interested to know what is the remedy to be taken to avoid this error? Could you please share what are the steps/modifications that were done to avoid the error?
Description of my error: I get similar kind of error in OF1.6 version for the modified coalChemistryFoam. Instead of char burning, I have implemented char-gasification chemistry (hetrogeneous chemistry).
Thanks,
Nir
N. A. is offline   Reply With Quote
Old   May 16, 2011, 02:35
桂莹
yingkun is on a distinguished road
Hi,Andrew
you said the tutorial have been updated in 1.7.x,I use OF1.7.1,it's still the same problem,I hope you can help me ,and what is updated in new version?
thank u!
yingkun is offline   Reply With Quote
Old   June 13, 2011, 23:18
桂莹
Hi,Nir
do you use coalChemistryFoam?my case has two inlets/one outlet,I use the updated OF,and for my case it shows the same "out of temperature range"problem,do you know how to solve it?
Best regards
ying
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 13:29
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
