Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
foamToVTK & foamDataToFluent problem!
Old   August 16, 2010, 03:57
Default foamToVTK & foamDataToFluent problem!
Björn
germinal is on a distinguished road
Hi!
I try to convert my results (fireFoam tutorial im OpenFOAM 1.7) to VTK or .data but I get:
--> FOAM FATAL IO ERROR:
Cannot find 'value' entry on patch base of field IDefault in file "/model/villami/OpenFOAM/villami-1.7.0/run/tutorials/combustion/fireFoam/les/smallPoolFire2D/0/IDefault"
which is required to set the values of the generic patch field.
(Actual type greyDiffusiveRadiation)
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file: /model/villami/OpenFOAM/villami-1.7.0/run/tutorials/combustion/fireFoam/les/smallPoolFire2D/0/IDefault::boundaryField::.* from line 25 to line 28.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file genericFvPatchField/genericFvPatchField.C at line 71.
FOAM exiting
Whats up here???
Thanks in advance for your help :-)
germinal is offline   Reply With Quote
Old   August 17, 2010, 05:02
Default IDefault (greyDiffusiveRadiation)
Sergio Ferraris
SergioF is on a distinguished road
There was a misspelling on the IDefault entry in the zero folder (semi colon missing). The change has been updated into 1.7.x
Thanks
Sergio
SergioF is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
convergence problem Trushar Phoenics 5 August 27, 2002 23:40
