March 14, 2011, 09:07 |
Problem gmshToFoam
i have created mesh by gmesh 2.7 & I would like to use it with OpenFoam 1.7.1 the command gmshtoFoam displays fatal error message (see below). Do you have any ideas about this problem ?? Thank you in advance. Lucy --------------------------------------------------------------------------------------------- /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-4bbf33160caf Exec : gmshToFoam cav1.msh Date : Mar 14 2011 Time : 13:48:03 Host : spartan-VirtualBox PID : 2561 Case : /home/spartan/Documents/projnum/tutorials/incompressible/icoFoam/cavity nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Found $MeshFormat tag; assuming version 2 file format. Starting to read mesh format at line 2 Read format version 2.2 ascii 0 Starting to read physical names at line 5 Physical names:7 Surface 1 front Surface 2 back Surface 3 bottom Surface 4 top Surface 5 left Surface 6 right Volume 7 internal Starting to read points at line 15 Vertices to be read:0 Vertices read:0 Starting to read cells at line 18 Cells to be read:0 Cells: total:0 hex :0 prism:0 pyr :0 tet :0 --> FOAM FATAL IO ERROR: No cells read from file "cav1.msh" Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)? Perhaps you have not exported the 3D elements? file: cav1.msh at line 20. From function readCells(..) in file gmshToFoam.C at line 719. FOAM exiting |
November 1, 2011, 08:52 |
Hi Lucy!!
There is a problem when using converter gmshToFoam. Did u rename the Physical Group in *.geo file? Like Surface 1 front Surface 2 back Surface 3 bottom Surface 4 top Surface 5 left Surface 6 right Volume 7 internal Then openFoam cannot read. I don't know why. So I didn't rename the physical group. Instead I open the *.msh file from Engits, using Import > Gmsh (2.0.0) and then give the boundary name using Edit Boundary Condition. The you can export the mesh in openFoam format, using Export> OpenFoam (grid only). It works. But it works only in Windows. I can't do it in Linux. Good luck!! PS: Just follow the link u can download engits both for Window and Linux. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
