Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
alphaContactAngle patch type does not work in OF-1.6
Like Tree2Likes
  • 2 Post By sundaero
Old   September 24, 2009, 20:14
Default alphaContactAngle patch type does not work in OF-1.6
Denis Semyonov
sundaero is on a distinguished road
Hello, everybody.
I found out that the new patch type alphaContactAngle which has replaced previously used constantGammaContactAngle for the interFoam solver does not work properly.
Consider given tutorial example damBreak using laminar turbulence model.
If you follow the User Guide and replace in the 0/alpha1 file any wall boundary patch from zeroGradient to something like:
boundaryField
    leftWall
//        type            zeroGradient;
        type            alphaContactAngle;
        theta0          40;
        thetaA          70;
        thetaR          10;
        uTheta          1;
        value           uniform 1;
then you will get the following error message:
damBreak> interFoam
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6-f802ff2d6c5a
Exec   : interFoam
Date   : Sep 25 2009
Time   : 02:56:41
Host   : kowalski
PID    : 18331
Case   : /home/semyonov/OpenFOAM/semyonov-1.6/run/damBreak
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Not Implemented
    Trying to construct an genericFvPatchField on patch leftWall of field rho#0  Foam::error::printStack(Foam::Ostream&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  Foam::genericFvPatchField<double>::genericFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#3  Foam::fvPatchField<double>::addpatchConstructorToTable<Foam::genericFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#4  Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam"
#5  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::List<Foam::word> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam"
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::List<Foam::word> const&) in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam"
#7  main in "/home/semyonov/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam"
#8  __libc_start_main in "/lib64/libc.so.6"
#9  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
    From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF)
    in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 45.
FOAM aborting
Aborted
Does that mean that this patch type is simply not yet implemented in OF-1.6?
Just in case I have also tried to set this patch to constantGammaContactAngle and alpha1ContactAngle, but neither works.
I am not very familiar with the source code. How can I check the list of the available and implemented boundary patche types?
Denis
sundaero is offline   Reply With Quote
Old   September 25, 2009, 04:04
henry is on a distinguished road
alphaContactAngle is the abstract base-type with concrete implementations:
constantAlphaContactAngle
dynamicAlphaContactAngle
timeVaryingAlphaContactAngle
I think you need constantAlphaContactAngle for your case.
H
henry is offline   Reply With Quote
Old   September 25, 2009, 04:51
bfa
Björn Fabritius
bfa is on a distinguished road
different case, similar problem:
I tried to convert a OF 1.5-dev case with moving mesh to OF 1.6. First of all: Why is it that I now have to provide cellMotionU AND pointMotionU when using the velocityLaplacian motionSolver instead of just giving motionU as of version 1.5?
But the real problem is that I used the oscillatingFixedValue b.c. on a patch for movement, but that leads to
Not Implemented
    Trying to construct an genericFvPatchField on patch topStamp of field cellMotionU#0
As Henry mentioned, this b.c. might be a virtual one, but browsing the code shows me that it's not (it can be found in OpenFOAM-1.6/src/finiteVolume/fields/fvPatchFields/derived)
Any ideas how to use this or another b.c. that does the same job with a moving wall?
tx, bjoern
bfa is offline   Reply With Quote
Old   September 25, 2009, 12:41
Denis Semyonov
Thank you, Henry.
Suggestet patch types working well in the damBreak example of OF-1.6.
I guess it was just too late yesterday, so I forgot to simply replace constantGammaContactAngle with the constantAlphaContactAngle and thought that there is something wrong with OpenFOAM installation.
Denis
Old   December 8, 2009, 03:40
Default Not yet figured out!
Claus Meister
idrama is on a distinguished road
Hello sundaero!
Could you please post your final alpha1 file with the modified contact angle? Because I haven not yet figured out how it works.
Cheers,
Claus
idrama is offline   Reply With Quote
Old   December 8, 2009, 09:14
Denis Semyonov
Here it goes (implementation of the dynamic contact angle):
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha1;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    FRONT_WALL
        type            empty;
    BACK_WALL
        type            empty;
    OUTLET
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    GAS_INLET
        type            fixedValue;
        value           uniform 0;
    CATALYST
        type            dynamicAlphaContactAngle;
        theta0          40;
        thetaA          70;
        thetaR          10;
        uTheta          1;
        value           uniform 1;
    LIQUID_INLET
        type            zeroGradient;
        type            fixedValue;
        value           uniform 1;
    TOP_WALLS
        type            zeroGradient;
    LEFT_RIGHT
        type            cyclic;
        value           uniform 1;
BR
Denis
koooje and yeyinglcn like this.
Old   June 16, 2010, 11:11
Default Similar error, different cause
Mark Couwenberg
markc is on a distinguished road
Hello All,
I have the similar error (Not implemented, trying to construct an gFPF on patch ... of field rho#()). The error is being generated by the file genericFvPatchField.C.
However, I am doing something else: I created a private boundary condition which is based on timeVaryingUniformFixedValue which is intended to be used on alpha1 field only. It compiles well. But at runtime I get that specific error.
My 0/alpha1 for that specific patch looks like
type surfaceWaveAlpha;
value uniform 0;
Because the error message is complaing about rho, I also tried adding : rho rho, without result.
Can anyone give me some hints here, althoug I admit that the description might be a bit vague...
Thanks in advance,
Mark
markc is offline   Reply With Quote
Old   June 18, 2011, 04:45
azar
ajamy is on a distinguished road
Hi, i am realy confused
whats the meaning of the 'thataA","theta0","thetaR" and "utheta"?
can you tell me a bout it briefly?
tnx
ajamy is offline   Reply With Quote
Old   March 19, 2012, 22:23
bibin
koooje is on a distinguished road
Dear Henry,
I am a new user and I am trying to implement slug-plug flow of water in oil in a 250micon closed square channel. I have a relation which goes like thetaA=thetaA0+const*Ca^(1/3) for advancing CA and thetaR=thetaR0-const*Ca^(1/3) for receding CA, both based on Tanner's law. The difference in thetaA0 and thetaR0 is the contact angle hysteresis. I am trying to understand the shape of droplets under the influence of contact angle hysteresis. Could you please explain with a sample code, if possible how to implement dynamicAlphaContactAngle in /0/alpha1. I believe it goes into the boundary condition in alpha1. Your reply is deeply appreciated.
Thanks,
Koooje
koooje is offline   Reply With Quote
Old   April 1, 2012, 19:40
bibin
Go to : opt/openfoam210/src/transportModels/twoPhaseInterfaceProperties/alphaContactAngle for the implementation of dynamicAlphaContactAngle
Check out the file 'dynamicAlphaContactAngleFvPatchScalarField.C' and 'dynamicAlphaContactAngleFvPatchScalarField.H' to find the meaning of all the parameters you asked for. The theta is specified by the formula theta=theta0_ + (thetaA_ - thetaR_)*tanh(uwall/uTheta_). If you plot this formula with matlab/mathematica you can see how theta varies with different parameters.
Koooje
Old   April 13, 2012, 18:08
Nikhil
Nikhilcfd is on a distinguished road
Hello Koooje,
To implement your new dynamic contact angle BC, start off by copying the existing files of dynamic contact angle implementation. You need to calculate the capillary number by creating volScalarField 'mu' in createField.H file and update it every iteration. Call the 'mu' from your new files and calculate the capillary number. Once you calculate that you can use your theta expressions. All you need to do is change the way theta is being calculated and return it to interface.C file which takes care of the correction. Hope this helps.
Nikhil
Nikhilcfd is offline   Reply With Quote
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
