Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Strange rhoCentralFoam behavior after restart...
Like Tree1Likes
Old   October 31, 2011, 09:55
Question Strange rhoCentralFoam behavior after restart...
Vesselin Krastev
vkrastev is on a distinguished road
Hi all,
well I don't know if this can be considered a real bug, but I've noticed a really strange (and highly undesirable) behavior of the rhoCentralFoam solver when a simulation is stopped and then restarted from the stop point...A brief description of my case: I'm trying to get some aerodynamic torque evaluations on a 2D simple throttle valve geometry; the flow is pressure driven (fixed pressures at inlet and outlet of the duct containing the valve) and till now I'm getting good overall results (except for some strange little pressure/velocity oscillations, which seem to be peculiar of the rhoCentralFoam solver). The fact is that being the runs quite long (it tooks about 2 days to simulate 0.1 s of physical time), I need sometimes to stop-and-restart the simulations at some point, but... when I first restarted a simulation and took a look on the torque plot from the forces function I got a very sharp discontinuity! I mean, If run the case from t=0 to, let's say, t=0.1 s I get some torque plot; otherwise, if I stop the original run at, let's say t=0.05 s, and then restart it, the plot re-starts from a completely different point and thus the final torque value (at t=0.1 s) is also very different! I'm sure that is not a problem of the forces function, because I've also checked the pressure distribution around the valve and there is indeed a sudden change immediately after the restart!
Any opinion about this matter? Is this a problem encountered also by someone else?
For more clearness a picture of a torque plot with two different restarts is attached below
Regards
V.
vkrastev is offline   Reply With Quote
Old   October 31, 2011, 10:11
Sandeep Menon
deepsterblue will become famous soon enough
Since this run is transient, I would imagine that there's an "old-time" value that is required in the computation, but isn't written out to disk. Usually, fields, etc tend to be initialized with the current value if an old-time value was not found. You might want to check on that...
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   October 31, 2011, 10:49
Vesselin Krastev
Hi Sandeep, and thanks for the reply. Sorry for my persistence, but could you clarify what do you mean with "old" and "current" values?
V.
Old   October 31, 2011, 10:58
Sandeep Menon
Old - when referring to the state of the field in the previous time-step.
Current - when referring to the state of the field in the current time-step.
If you're dealing with fields, that is. I might be wrong too, since I would expect torque to be instantaneous, and wouldn't normally associate it with an old-time value...
It's just that when I see restart issues like this, the first thing to check would be whether old-time values are being stored / retrieved appropriately from disk..
Sandeep Menon
Old   October 31, 2011, 12:34
Vesselin Krastev
Ok, thanks once again. Actually you made me think about a possible explanation for this behavior: the problem could be localized not in the old-values reading, but in the data storage precision (the torque values here are pretty small, thus prone to fluctuations with very small pressure variations over the valve surface). I'm doing some tests now increasing a lot the write precision, so let's see what happens...
V.
Old   November 1, 2011, 17:46
Alberto Passalacqua
Store data in binary format to see if it makes a difference.
ASCII format makes it easier to edit the case, but binary is recommended not to lose information. Additionally, you can convert from one into the other.
Alberto Passalacqua
Old   November 2, 2011, 04:25
Vesselin Krastev
Thanks, I'll try it.
V.
Old   November 2, 2011, 13:48
Vesselin Krastev
Well, I'm starting to worry seriously about this restart matter...I've selected binary as output and increased the write precision a lot, but the result is absolutely not encouraging (see the image attached below)...Could this be reported as a bug of the rhoCentralFoam solver or I'm missing something else? Any help/idea would be really appreciated
Regards
V.
Old   November 2, 2011, 14:06
Alberto Passalacqua
I would report
Alberto Passalacqua
Old   November 2, 2011, 17:30
Vesselin Krastev
I would report
Reported! (let's see what happens)
Old   November 8, 2011, 13:06
Default Bug fixed
  #11
Vesselin Krastev
Hi all,
there was actually a problem in the updating of the flux phi, which has been fixed today with the following OF-2.0.x commit
commit dc17e722ab2a9539775eec59650e6dc0e7eb9360
The bug is present both in OF-1.7.x and OF-2.0.x families, and can be fixed in the same way also for 1.7.x. I think it is important to know for all users that if not fixed, that bug can lead to significantly erroneous results using rhoCentralFoam, as an error seems to propagate through time because of the incorrect phi update (see this page for more details http://www.openfoam.com/mantisbt/view.php?id=332 )
Best
V.
Old   November 8, 2011, 14:15
Alberto Passalacqua
Thanks for the update!
Alberto Passalacqua
Old   November 8, 2011, 16:00
Vesselin Krastev
You are welcome!
Old   November 8, 2011, 21:15
Praveen. C
praveen is on a distinguished road
Originally Posted by vkrastev View Post
Hi all,
Best
V.
But what was the bug ? Looking at the changes
https://github.com/OpenFOAM/OpenFOAM...oCentralFoam.C
I fail to understand what the bug was ?
praveen is offline   Reply With Quote
Old   November 9, 2011, 04:02
Vesselin Krastev
I think (but I'm not sure of it) that the problem was a redundance in the phi declaration between the createFields.H and the rhoCentralFoam.C files
Regards
V.
Old   November 10, 2011, 02:43
Laurens Van Dyck
laurensvd is on a distinguished road
A beginners question (but googling for commit doesnt seem to work ), how do you 'commit' such an update? Is it related to svn (my it-administrator doesnt allow this)? If its just the rhoCentralFoam.C or rhoCentralFoam.H that is changed, could someone post this change so I can manually fix it if commit is no option? If the only change is the deletion of this one line of code for phi and adding the other as mentioned above, forget I asked something
laurensvd is offline   Reply With Quote
Old   November 10, 2011, 02:54
Praveen. C
Though there was a redundancy, I dont think phi was the problem. Time step does not seem to have been properly set for restarted cases. The below fix is also required for the same bug that vkrastev reported
https://github.com/OpenFOAM/OpenFOAM...99a8dbd3dbf211
Old   November 10, 2011, 07:40
Vesselin Krastev
No, the problem was actually phi: the time step initialization fixing does not have any effect on the restarting problem
V.
Old   November 10, 2011, 07:41
Vesselin Krastev
Search for github OpenFOAM 2.0.x and see the latest commits
V.
Old   November 10, 2011, 08:52
Praveen. C
V.
OK. Is phi used for some other purpose ? Why aren't the other fluxes phiUp and phiEp similarly declared in createFields.H ? Would like to understand this since I have modified rhoCentralFoam for my own needs.
Problem with multiframe restart of two-way fsi coupled problem Dimone CFX 26 December 20, 2011 10:10
Restart for solidification atulverma FLOW-3D 2 May 15, 2009 06:25
Restart for Solidification atulverma FLOW-3D 3 May 6, 2009 17:40
v4 restart bug optima prime Siemens 3 February 2, 2009 22:51
Restart of FSI simulation V. Kumar CFX 3 July 20, 2006 13:23
