Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
snappyHexMesh is generating cells with flat faces touching each other
Old   January 19, 2015, 03:55
Exclamation snappyHexMesh is generating cells with flat faces touching each other
chriss85 will become famous soon enough
I've recently run into problems where snappyHexMesh will generate polyhedra cells with a nonzero volume, but two faces directly on top of each other.
This results in problems because the Courant number will be extremely high in these cells, and adaptive time step methods will fail.
This problem is not detected by checkMesh, since common quality measures like non-orthogonality or cell volume are unaffected. I think this issue needs to be considered in the detection of invalid cells during undo stage in snappyHexMesh.
For reference, here's the checkMesh output:
    Overall domain bounding box (-2.10476e-08 1.47089e-05 1.07802e-05) (0.017315 0.0186159 0.0183828)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-8.91807e-17 -2.58947e-17 -6.77004e-18) OK.
    Max cell openness = 3.89026e-16 OK.
    Max aspect ratio = 5.73767 OK.
    Minimum face area = 4.2135e-10. Maximum face area = 4.23884e-08.  Face area magnitudes OK.
    Min volume = 4.94644e-14. Max volume = 7.47925e-12.  Total volume = 3.39481e-07.  Cell volumes OK.
    Mesh non-orthogonality Max: 55.4823 average: 10.0927
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.68602 OK.
    Coupled point location match (average 0) OK.
If any further information is required, feel free to ask me.
chriss85 is offline   Reply With Quote
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
