[swak4Foam] Compiliation of swak4Foam
Old   March 11, 2015, 08:45
Default Compiliation of swak4Foam
Tomladian Bucinara
Tom123 is on a distinguished road
Greetings Everyone,
I am using Ubuntu 14.1 and OpenFOAM 2.3.0; I downloaded swak4Foam from the following link:
https://openfoamwiki.net/index.php/I...am/Downloading
this is fine and try to compile it, gives this error:
Previously compiled for OpenFOAM 2.3.0
No file 'swakConfiguration'. Python etc won't work. See README for details
Checking swak4Foam-version and generating file
./Allwmake: line 55: ./maintainanceScripts/makeSwakVersionFile.py: Permission denied
/home/toml/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake: 181: /home/toml/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake: ./Allwmake: Permission denied
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
Anyone could help me fix this problem? Please. Thanks in advance.
Tom
Tom123 is offline   Reply With Quote
Old   March 12, 2015, 02:57
Tomladian Bucinara
anyone helps, please
Old   March 12, 2015, 04:36
Elvis
elvis will become famous soon enough
did you read
https://openfoamwiki.net/index.php/I...ling_On/Ubuntu
=>No file 'swakConfiguration'. Python etc won't work. See README for details
https://github.com/Unofficial-Extend.../master/README
*** Additional configurationSome features (currently only the =Python=-integration may needthird party software. The paths to these packages can be configuredin a file =swakConfiguration= (an example file=swakConfiguration.example= is provided). If that file is notpresent these unconfigured features will not be compiled.
=>Permission denied
have a look "ls -l" at the permission
you know how to use the linux "chmod" command?
elvis is offline   Reply With Quote
Old   February 29, 2016, 10:12
Peng Liang
tjliang is on a distinguished road
Originally Posted by Tom123 View Post
Greetings Everyone,
Tom
I also have the problem :/home/toml/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake: 181: /home/toml/OpenFOAM/OpenFOAM-2.3.0/wmake/wmake: ./Allwmake: Permission denied.
Could you tell me how did you solve that? thanks.
Best Regards,
Peng
tjliang is offline   Reply With Quote
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[swak4Foam] and twoPhaseEulerFoam mnikku OpenFOAM Community Contributions 1 February 19, 2016 05:21
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 10:31
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
