[swak4Foam] single scalar variable in swak function working on cellSet
Old   January 30, 2016, 09:06
Default single scalar variable in swak function working on cellSet
Duncan Roy van der Heul
Duncan_vdH is on a distinguished road
In my swak function object I want to set the value of a global variable to the sum of
the values of a variable defined in a cellSet.
The global value has fieldSize 1, but the storedVariables one and two have fieldSize
4000, equal to the number of cells in the set. How do I get a storedVariable of
fieldSize 1 equal to the average value over the cellSet? The syntax is not clear to me.
average(one) is again a variable with fieldSize 4000.
myFunction {
        globalScopes (
          my_globalvariables
        type calculateGlobalVariables;
        outputControl timeStep;
        outputInterval 1;
    noReset  true;
        valueType cellSet;
        setName my_set;
        storedVariables (
                name one;
                initialValue "0";
            {   name two;
            initialValue "0";
    my_global_var=sum(one);
Duncan_vdH is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
using a Fortran library of thermodynamics inside sutherland transport model Mehdi3031 OpenFOAM Programming & Development 0 April 7, 2016 09:34
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
