[swak4Foam] FunkySetFields for OF 141
Like Tree1Likes
Old   February 26, 2008, 15:54
Default FunkySetFields for OF 141
mer
merrouche djemai
mer is on a distinguished road
Did the latest version of FunkySetFields.r7568 work with OF 1.4.1. I try to compile it, but there are some errors?
I hope that I find a quick response.
Djemai
mer is offline   Reply With Quote
Old   February 27, 2008, 06:37
Default Hi Djemai! That's right. Th
Assistant Moderator
Bernhard Gschaider
Hi Djemai!
That's right. That version only compiles with 1.4. Get the svn-version with the command described above the file that you downloaded
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 27, 2008, 16:47
Default Thank you Bernhard.
mer
merrouche djemai
Thank you Bernhard.
Old   March 1, 2008, 07:58
Default Hi all, I have recently compi
mer
merrouche djemai
Hi all,
I have recently compiled funkySetfields for OF 1.4.1, but when I run the utility I get some errors:
#0 Foam::error::printStack(Foam:stream&) in "/home/mer/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/mer/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x6d6420]
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/home/mer/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::tmp<foam::geometricfield<double,> > Foam::sqrt<foam::fvpatchfield,>(Foam::GeometricFie ld<double,> const&) in "/home/mer/OpenFOAM/mer-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields"
#5 .L30835 at ValueExpressionParser.C:0
#6 ValueExpressionDriver::parse(std::string const&) in "/home/mer/OpenFOAM/mer-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields"
#7 doAnExpression(Foam::fvMesh const&, Foam::word const&, Foam::string const&, Foam::string const&, Foam::Time const&, bool, bool, Foam::dimensionSet const&, bool, Foam::List<foam::word> const&) in "/home/mer/OpenFOAM/mer-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields"
#8 main in "/home/mer/OpenFOAM/mer-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields"
#9 __libc_start_main in "/lib/i686/nosegneg/libc.so.6"
#10 Foam::regIOobject::readIfModified() in "/home/mer/OpenFOAM/mer-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields"
Floating point exception
Did anyone have an idea how to resolve this problem?
Thanks
Djemai
Old   March 1, 2008, 08:53
Default What is the expression you're
Assistant Moderator
Bernhard Gschaider
What is the expression you're calculating? Is there a sqrt in it? By any chance a squareroot of a negative value? Because that is my suspicion when I look at #4 in your stacktrace
Old   March 1, 2008, 12:30
Default Hi Bernhard, Yes in my expres
mer
merrouche djemai
Hi Bernhard,
Yes in my expression there is a sqrt, but there is no negative value inside because all terms are powered to 2. simply it is an equation of a sphere add to other positive terms.
Djemai
Old   March 3, 2008, 04:34
Default Could you please post the expr
Assistant Moderator
Bernhard Gschaider
Could you please post the expression anyway? The problem is definitly happening during the evaluation of the sqrt. On possibility to check: Let the utility calculate the expression INSIDE the sqrt and check the result (for NaNs etc)
Old   March 3, 2008, 07:56
Default Hi Bernhard, I downloaded y
Thomas Sponfeldner
tspon is on a distinguished road
Hi Bernhard,
I downloaded your svn-Version of funkySetFields from the wiki and renamed all files in order to get C-Files etc.
But I do not know how to compile. I already tried "bison ValueExpressionParser.yy" to get .tab-Files but doesn't help (version 2.3). I also tried a wmake but it stopped and make writes: no rule to make target "funkySetFields.dep".
Could you please help me?
I use OF1.4.1.
Regards,
Thomas
tspon is offline   Reply With Quote
Old   March 3, 2008, 09:29
Default Hi Bernhard, Excuse me to tak
mer
merrouche djemai
Hi Bernhard,
Excuse me to take your time. Yes, it is my error. I put a sqrt in place of sqr inside the expression: sqrt(sqr(pos().x -2.*pow(10.,-2.))+sqr(pos().y -2.*pow(10.,-2.))+ sqr(pos().z -3.*pow(10.,-2.)))<=0.0001 ? 1:0
But I have another problem. using this expression with funkySetFields it doesn't initiate my field. I verify the same equation with setGammaDamBreak and it works. What is the problem.
Old   March 3, 2008, 11:07
Default Hi Thomas, I have compiled th
mer
merrouche djemai
Hi Thomas,
I have compiled the last svn-Version of funkySetFields without any errors. To be sure that you are in the good way:
1) try to see if you have bison: bison -V
2) don't forget to run insertGenerated.sh
3) wmake should be inside the
funkySetFields directory with the presence of Make directory.
Hope this will help.
Djemai
Old   March 3, 2008, 14:18
Default Hi Djemal! At first: it sho
  #11
Assistant Moderator
Bernhard Gschaider
Hi Djemal!
At first: it should be possible to write 2e-2 instead of 2*pow(10.,-2). This would a) make the expression simpler and b) reduce the computation time (because 2*pow(10,-2) will be computed for every cell. Have you tried to make the radius (which is 2 orders of magnitude smaller than the coordinates of the midpoint) much larger? I mean: how large are your cells? With that difference in magnitudes it might be possible, that no cell-center fits your condition
Bernhard
Hi Thomas!
Did you download it using svn or via the web-browser? Because I was weondering why there was any need to rename the C-files?
Bernhard
Old   March 4, 2008, 04:29
Default Hi Bernhard an Djemai, than
  #12
Thomas Sponfeldner
thanks for your help. It works now. I had some problems with my browser, therefore I had to rename all the files. But after downloading them from anonther pc the files remained unchanged and wiki-instructions worked fine.
Regards,
Thomas
Old   March 4, 2008, 07:52
Default Hi Bernhard and Djemai, it
  #13
Thomas Sponfeldner
it works now. I had some problems with my browser therefore I had to change the filenames. But using another pc the files remained unchanged and wiki instructions worked fine. Thanks for your help and the quick replies.
Regards,
Thomas
Old   March 4, 2008, 10:19
Default Hi Thomas! With SVN-Archive
  #14
Assistant Moderator
Bernhard Gschaider
Hi Thomas!
With SVN-Archives the browser is only good for looking at the stuff. Use the svn-command to actually "download" it.
Bernhard
Old   March 7, 2008, 04:12
Default Hi Bernhard ! thank you, I un
  #15
mer
merrouche djemai
Hi Bernhard !
thank you, I understand and it works.
Djemai
Old   May 18, 2008, 03:28
Default I used funkySetFields to creat
  #16
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I used funkySetFields to create a spherical initial condition:
funkySetFields . . -field gamma -expression 1 -condition "pos().x*pos().x + pos().y*pos().y <= 1" -time 0
I didn't had the chance to say if the condition is right, because there was this error:
--> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 1
Looks like there is a problem with the mesh.
Does anybody know, what went wrong?
blockMeshDict
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 18, 2008, 07:11
Default Hi Sebastian, You can read th
  #17
Takuya OSHIMA
7islands is on a distinguished road
Hi Sebastian,
You can read the error message straightforwardly: patch (1 2 14 13) is missing in leftAndBottom.
And don't forget to scale the expression given to FSF, e. g. pos().x*pos().x + pos().y*pos().y <= 0.02*0.02,
since there's convertToMeter 0.01; in your blockMeshDict.
Takuya
7islands is offline   Reply With Quote
Old   May 18, 2008, 12:56
Default Hello Takuya. Of course. Th
  #18
sega's Avatar
Sebastian Gatzka
Hello Takuya.
Of course. That solved the problem.
But the simulation is not running as planned.
As this has nothing to do with funkySetFields I will talk about it in another thread the next days.
Thanks. S.
Old   May 29, 2008, 06:16
Default Hi all Lately I have been w
  #19
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi all
Lately I have been working with waves over submerged bars, and I have experienced a problem when initializing the gamma-field. I am using hex-cells and initializing with setFields (SF), but as I can see that the problem would arise from using funkySetField (FSF) as well. The problem is seen in the following figure:
SF and FSF initializes based on the cell center coordinate, thus a cell might be partly full but the fraction of gamma is only set to either 0 or 1, which results in the step-like feature of the attached figure.
I am considering making a routine - even though it might be some time into the future, as its priority is very low - which calculates the wet and dry fractions of these partially full cells. This would enable an initialization of the surface, which is perfectly flat and thus the fast moving surface waves, which I am struggling with at the moment, will be history.
Thus my questions are two-fold:
1. Would people be interested in such a tool?
2. The mesh generator has some routine to calculate the cell volumes based on an arbitrary shape. Could any of you point me to where it happens, as I am not strong in calculating the volume of arbitrarily shaped cells.
Best regards,
Niels
vsammartano likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 29, 2008, 08:35
Default Hi Niels! Maybe a quick fix
  #20
Assistant Moderator
Bernhard Gschaider
Hi Niels!
Maybe a quick fix could be the following expression in funkySetFields (havn't got the time to try this out so the syntax might be slightly wrong):
"average(fpos().y < 0 ? 1 : 0)"
This constructs a face-field according to the criterium and then creates the cell field by averaging the values on the faces. This should smoothen things out a bit
All the functions are described on http://openfoamwiki.net/index.php/Co...funkySetFields
Bernhard
PS: Let me know if you have any problems. This part of FSF is not too well tested
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 09:01
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 02:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 19:07
[swak4Foam] funkySetFields: problem with processor boundary nmikhailov OpenFOAM Community Contributions 4 May 26, 2015 09:48
[swak4Foam] numerical beach with funkySetFields?! maxonline OpenFOAM Community Contributions 6 June 17, 2011 04:59
