[swak4Foam] Implementation of Robin BC by groovyBC : difference wrt. theoretic solution
Old   April 9, 2012, 11:24
Default Implementation of Robin BC by groovyBC : difference wrt. theoretic solution
Tianyi LI
tianyikillua is on a distinguished road
Hello everyone, we consider the following stationary heat equation:
Laplacian(T)=0
-----------T(x)---------- a bar with length L=0.4 m, mesh Delta x=1 mm
x=0        x           x=L (patch outlet)
BC :
At x=0 : T(0)=T0=273 K
At x=L : kT'(x)=h*(T(L)-Tinf) with k=237 W/mK, h=-100 W/m^2K, Tinf=873 K
We have implemented this BC using swak4Foam, in 0/T for the patch outlet:
    	type                groovyBC;
    	variables           "k=237;h=-100;Tinf=873;";
    	valueExpression     "Tinf";
    	fractionExpression  "1/(1-k/(mag(delta())*h))";
    	value	            $internalField;
We are using the "steadylaplacianFoam" where we solve only the stationary heat equation. After about 5 iterations the solution OF has converged.
However, the OF solution differs a little from the theoretic solution :
tianyikillua is offline   Reply With Quote
Old   April 11, 2012, 16:20
Assistant Moderator
Bernhard Gschaider
Laplacian(T)=0
BC :
    	type                groovyBC;
Attachment 12409
Convergence is relative. Have you tried a stricter convergence criterion? Also try varying the mesh resolution to see if this is not just a discretization problem
Old   April 12, 2012, 10:33
Tianyi LI
After we changed the gradient scheme to leastSquares, everything is fine !! However we still don't know why...
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
[swak4Foam] A way to update groovyBC variables during the solution immortality OpenFOAM Community Contributions 10 February 4, 2013 00:56
[swak4Foam] no change in solution by change in groovyBC variables immortality OpenFOAM Community Contributions 2 January 28, 2013 07:34
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
