[OpenFOAM.org] OpenFOAM 2.3.x on Mac OS X 10.10.1 Installation Errors
Like Tree1Likes
  • 1 Post By windscion
Old   March 4, 2015, 03:47
Default OpenFOAM 2.3.x on Mac OS X 10.10.1 Installation Errors
Paolo
Petru is on a distinguished road
I'm new here, and I have no experiences with these kind of things.
I'm trying to install OpenFOAM 2.3.x on my Mac OS X 10.10.1 since some days without any result.
I also tried to run different installation process, but everytime there are still some errors.
Right now, I'm applying this process:
http://openfoamwiki.net/index.php/In...OpenFOAM_2.3.x
But I still can not install it, cause some errors.
First of all, I can not correctly set mp-llvm-3.5 for llvm:
port select --summary
Name     Selected               Options
db       db48                   db48 none
gcc      mp-gcc48               mp-gcc48 mp-gcc49 none
ipython  none                   none
llvm     none                   mp-llvm-3.5 none
mpi      openmpi-gcc48-fortran  openmpi-gcc48-fortran openmpi-mp-fortran none
python   python27               python26-apple python27 python27-apple none
When I try to set the llvm port with:
sudo port select --set llvm mp-llvm-3.5
I receive this message:
Selecting 'mp-llvm-3.5' for 'llvm' failed: symlink: /opt/local/etc/select/llvm/current -> mp-llvm-3.5: file already exists
I don't know if it could be the problem, however when I try to install OpenFOAM, I receive this error message (first part of the log.Allwake):
mpicc -m64 -fsignaling-nans  -ftrapping-math  -Wall -O2   -fPIC -Ddarwin dirToString.c -o /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/dirToString
dyld: Library not loaded: /usr/local/lib/libopen-pal.6.dylib
  Referenced from: /usr/local/bin/mpicc
  Reason: Incompatible library version: mpicc requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0
make: *** [/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/dirToString] Trace/BPT trap: 5
no ThirdParty sources found - skipping
+ wmakePrintBuild -check
version changed from previous build
+ /bin/rm -f 'OpenFOAM/Make/*/global.?'
+ wmakeLnInclude OpenFOAM
wmakeLnInclude: linking include files to OpenFOAM/lnInclude
+ wmakeLnInclude OSspecific/POSIX
wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude
+ Pstream/Allwmake
+ wmake libso dummy
wmakeLnInclude: linking include files to ./lnInclude
/bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory
SOURCE=UPstream.C ;  mpicxx -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/UPstream.o
  Referenced from: /usr/local/bin/mpicxx
  Reason: Incompatible library version: mpicxx requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0
/bin/sh: line 1: 79047 Trace/BPT trap: 5       mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/UPstream.o
make: *** [Make/darwinIntel64GccDPOpt/UPstream.o] Error 133
+ case "$WM_MPLIB" in
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
wclean mpi
wmake libso mpi
SOURCE=UOPwrite.C ;  mpicxx -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/opt/local/include/openmpi-mp -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o
/bin/sh: line 1: 79134 Trace/BPT trap: 5       mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/opt/local/include/openmpi-mp -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o
make: *** [Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o] Error 133
+ OSspecific/POSIX/Allwmake
SOURCE=signals/sigFpe.C ;  mpicxx -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/sigFpe.o
/bin/sh: line 1: 79294 Trace/BPT trap: 5       mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/sigFpe.o
make: *** [Make/darwinIntel64GccDPOpt/sigFpe.o] Error 133
I can not understand what is going on.
I hope that some of you can figure out where is the problem.
Thank you,
Paolo
Petru is offline   Reply With Quote
Old   March 4, 2015, 04:10
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can try to delete /opt/local/etc/select/llvm/current and run "port select ..." again.
To diagnose your error, please provide output of the following commands:
  1. which mpicc
  2. mpicc --version
  3. mpicc --showme
  4. export | grep -E '(FOAM_|WM_)'
The last command will expose certain information about OpenFOAM installation location, though according to initial message it is not a concern for you.
alexeym is offline   Reply With Quote
Old   March 4, 2015, 14:28
Paolo
Thank you very much!!
The first problem is solved, now mp-llvm-3.5 is selected.
This is the answer code for the OF installation:
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ which mpicc
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ mpicc --version
Trace/BPT trap: 5
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ mpicc --showme
Trace/BPT trap: 5
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ export | grep -E '(FOAM_|WM_)'
declare -x FOAM_APP="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/applications"
declare -x FOAM_APPBIN="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/bin"
declare -x FOAM_EXT_LIBBIN="/Users/Paolo/OpenFOAM/ThirdParty-2.3.x/platforms/darwinIntel64GccDPOpt/lib"
declare -x FOAM_INST_DIR="/Users/Paolo/OpenFOAM"
declare -x FOAM_JOB_DIR="/Users/Paolo/OpenFOAM/jobControl"
declare -x FOAM_LIBBIN="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64GccDPOpt/lib"
declare -x FOAM_MPI="openmpi-macport-mp"
declare -x FOAM_RUN="/Users/Paolo/OpenFOAM/Paolo-2.3.x/run"
declare -x FOAM_SETTINGS=""
declare -x FOAM_SIGFPE=""
declare -x FOAM_SITE_APPBIN="/Users/Paolo/OpenFOAM/site/2.3.x/platforms/darwinIntel64GccDPOpt/bin"
declare -x FOAM_SITE_LIBBIN="/Users/Paolo/OpenFOAM/site/2.3.x/platforms/darwinIntel64GccDPOpt/lib"
declare -x FOAM_SOLVERS="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/applications/solvers"
declare -x FOAM_SRC="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src"
declare -x FOAM_TUTORIALS="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/tutorials"
declare -x FOAM_USER_APPBIN="/Users/Paolo/OpenFOAM/Paolo-2.3.x/platforms/darwinIntel64GccDPOpt/bin"
declare -x FOAM_USER_LIBBIN="/Users/Paolo/OpenFOAM/Paolo-2.3.x/platforms/darwinIntel64GccDPOpt/lib"
declare -x FOAM_UTILITIES="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/applications/utilities"
declare -x WM_ARCH="darwinIntel64"
declare -x WM_ARCH_BASE="darwin"
declare -x WM_ARCH_OPTION="64"
declare -x WM_BASE_COMPILER="Gcc"
declare -x WM_CC="mpicc"
declare -x WM_CFLAGS="-m64 -fPIC"
declare -x WM_COMPILER="Gcc"
declare -x WM_COMPILER_LIB_ARCH="64"
declare -x WM_COMPILE_OPTION="Opt"
declare -x WM_CXX="mpicxx"
declare -x WM_CXXFLAGS="-m64 -fPIC"
declare -x WM_DIR="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake"
declare -x WM_LDFLAGS="-m64"
declare -x WM_LINK_LANGUAGE="c++"
declare -x WM_MACPORT_MPI_VERSION="mp"
declare -x WM_MACPORT_VERSION=""
declare -x WM_MPLIB="MACPORTOPENMPI"
declare -x WM_OPTIONS="darwinIntel64GccDPOpt"
declare -x WM_OSTYPE="POSIX"
declare -x WM_PRECISION_OPTION="DP"
declare -x WM_PROJECT="OpenFOAM"
declare -x WM_PROJECT_DIR="/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x"
declare -x WM_PROJECT_INST_DIR="/Users/Paolo/OpenFOAM"
declare -x WM_PROJECT_USER_DIR="/Users/Paolo/OpenFOAM/Paolo-2.3.x"
declare -x WM_PROJECT_VERSION="2.3.x"
declare -x WM_THIRD_PARTY_DIR="/Users/Paolo/OpenFOAM/ThirdParty-2.3.x"
declare -x WM_USE_MACPORT="1"
Thank you again,
Paolo
Old   March 4, 2015, 15:07
Alexey Matveichev
Something strange happened with OpenMPI installation (either it is Macports "feature", or you have got libopen-pal.6.dylib from elsewhere). Please, post output of
port contents openmpi-gcc48-fortran | grep /lib
Maybe again (like with llvm) Macports were not able to create correct symlinks cause certain files were already in /usr/local/lib.
Old   March 4, 2015, 15:38
Paolo
There is no answer to the command:
Old   March 4, 2015, 20:07
Peter
opedrofunk is on a distinguished road
Looks like the "wrong" openmpi package is being selected? From your output:
You might try:
1) Uninstalling the openmpi-mp-fortran package, ie
sudo port uninstall openmpi-mp-fortran
2) Remove and reset the symlinks, ie:
sudo port select --set mpi none
sudo port select --set mpi openmpi-gcc48-fortran
3) Try compiling again.
opedrofunk is offline   Reply With Quote
Old   March 5, 2015, 02:57
Paolo
it can not be uninstalled:
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ sudo port uninstall openmpi-mp-fortran
Warning: no such port: openmpi-mp-fortran, skipping uninstall
Even if, the openmpi-mp-fortran port is present:
MacBook-Pro-Petr:OpenFOAM-2.3.x Paolo$ port select --summary
db       db48                   db48 none
ipython  none                   none
llvm     mp-llvm-3.5            mp-llvm-3.5 none
Moreover, I don't know if it could be the problem, but every time that I reset the terminal, it can not find the sudo port. In order to obtain the sudo port, I have to export the path with this command lines:
export PATH=$PATH:/opt/local/bin
export MANPATH=$MANPATH:/opt/local/share/man
export INFOPATH=$INFOPATH:/opt/local/share/info
Old   March 9, 2015, 05:40
Paolo
There is the ports list necessary for OpenFOAM . Maybe it could help in the understanding process.
It is the output of this command:
port list | grep -E '(mpi|scotch|metis|cgal|boost|cmake)'
Thank you
Paolo
port.list.txt
Old   March 9, 2015, 06:26
Alexey Matveichev
As it was my errorneous suggestion I post corrected command variant here also:
port installed | grep -E '(mpi|scotch|metis|cgal|boost|cmake)'
This time output should be much shorter.
Old   March 11, 2015, 10:05
Paolo
Hello guys,
As Peter told me I have changed the path, in order to fix it.
Now the new path is:
MacBook-Pro-Petr:~ Paolo$ echo $PATH
/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
I hope this is what is expected to be!
Whatever, I runned again the installation process.
And now it takes more time than before, and it gives to me different errors.
There is the first part of the log.Allwmake file.
I hope it can help us to find out the problem.
log.Allwmake.zip
Thanks again,
Paolo
Old   December 22, 2015, 07:13
Default OpenFOAM-v.2.3.x installation for OSX 10.10 Yosmite
  #11
Kaan
arikan is on a distinguished road
Hi guys,
I am trying to set OpenFOAM-v2.3.x on my Mac which is OS X 10.10.5 Yosemite. I am following openfoamwiki.net/index.php/Installation/Mac_OS/OpenFOAM_2.3.x these instructions.
I was trying to select db48.
sudo port select --set db db48
something went wrong and i got this massage
Selecting 'db48' for 'db' failed: The configuration file '/opt/local/etc/select/db/base' could not be opened.
I think i have similar problem to Petru's problem. How can i fix the problem.
Thank you.
Kaan
arikan is offline   Reply With Quote
Old   December 28, 2015, 10:37
Default Me three
  #12
Thomas Evans
windscion is on a distinguished road
OS = 10.10.5
Trying to build 2.3.x based on instructions elsewhere in this forum. This time
around I actually followed the directions as closely as possible. AFAICT I
patched the source correctly. Running in bash. Oh, and OpenFOAM is placed
on a disk with a journaled case-sensitive FS.
I failed to set db48 as default, failed with
"Selecting 'db48' for 'db' failed: The configuration file '/opt/local/etc/select/db/base' could not be opened."
but I am thinking that isn't the cause of my current difficulty.
port select --summary output:
cython none cython26 none
db none db46 db48 none
gcc mp-gcc48 mp-gcc47 mp-gcc48 mp-gcc49 mp-gcc5 none
mpi openmpi-gcc48-fortran mpich-gcc49-fortran mpich-mp-fortran openmpi-gcc48-fortran openmpi-gcc49-fortran openmpi-mp-fortran none
nosetests none nosetests26 none
python python27 python26 python26-apple python27 python27-apple none
python2 none python26 python26-apple python27 python27-apple none
wxWidgets none wxWidgets-3.0 none
Current directory = OpenFOAM-2.3.x/applications/utilities/mesh/conversion/ansysToFoam
Command and result as follows:
mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall \
-Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 \
-DNoRepository -ftemplate-depth-100 -IlnInclude -I. \
-I/Users/evans/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude \
-I/Users/evans/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC \
-Ddarwin -lpthread \
-L/Users/evans/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc48DPOpt/lib/openmpi-macport-gcc48 \
-lPstream Make/darwinIntel64Gcc48DPOpt/ansysToFoam.o \
-L/Users/evans/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc48DPOpt/lib \
-lOpenFOAM -ldl -lpthread -lm \
-o /Users/evans/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc48DPOpt/bin/ansysToFoam
Undefined symbols for architecture x86_64:
"yyFlexLexer::yywrap()", referenced from:
vtable for yyFlexLexer in ansysToFoam.o
ld: symbol(s) not found for architecture x86_64
collect2: error: ld returned 1 exit status
I tried to force feed it /opt/local/lib/libfl.dylib, which contains _yywrap(), and
which has x86_64 architexture. This made no difference. Also "libfl_pic.dylib"
This error keeps me from building. It is the only error to show up, so I assume that it is the same error that prevents me from building some core elements like writeMeshObj and zipUpMesh.
EDIT: Oh, it looks like the code breaks for flex 2.6.0 because the minor version is less than 34. How quaint. I have brutally hacked it, seems to be compiling.
windscion is offline   Reply With Quote
Old   December 28, 2015, 16:44
Default 2.3.x upgrade bison and flex
  #13
Peter
OSX usually ships with pretty old versions of Bison and Flex (which is where the errors are coming from).
It seems to be a pretty common problem across other applications (not just OpenFOAM), so as a first try, I would suggest installing more up-to-date versions of bison and flex. i.e.:
$ sudo port install bison
$ sudo port install flex
and then sudo port select --set ... as normal for each so that they are used instead of the system versions.
You may need to use the macports installed version of python as well, if you are going to use the bindings.
Anyway, give it a try and let us know how it goes!
Good luck!
Peter
Old   December 29, 2015, 10:57
Thomas Evans
Ironic, then, that it was a too recent version of flex that caused the problem.
Old   December 29, 2015, 12:36
Peter
Hi Thomas,
Glad it's working!
Would you mind elaborating just a bit on your fix?
Installing OpenFOAM on the Mac can be something of an adventure, so every problem/solution is helpful!
Thanks,
Peter
Old   December 29, 2015, 12:51
Default hack
  #16
Thomas Evans
% cd $WM_PROJECT_DIR
% find . -name '*.L' -print
Open all of the above in your fav editor (I use jEdit). Change all instances of
#if YY_FLEX_SUBMINOR_VERSION < 34
to
#if YY_FLEX_SUBMINOR_VERSION < 34 && YY_FLEX_SUBMINOR_VERSION > 0
I did say it was a hack, right? This gets around the SUBMINOR==0 problem with flex 2.6.0, but it's hardly a real solution. A real solution, however, would require knowing that YY_FLEX_MINOR_VERSION and YY_FLEX_MAJOR_VERSION are defined, which is beyond me since I do not have a clue about the build system in use here.
Pagoda likes this.
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
[OpenFOAM.org] Installation of OpenFOAM on Mac: STLsurfaceFormatASCII.o error? APCoding OpenFOAM Installation 1 October 30, 2016 11:52
[OpenFOAM.org] Installation notes: OpenFOAM 2.3.x (git repo) on OSX 10.9 opedrofunk OpenFOAM Installation 7 July 1, 2015 13:51
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
