[OpenFOAM.com] v1612+ [Windows] How to change the workingDir shared folder?
Like Tree1Likes
  • 1 Post By LThomes
Old   May 18, 2017, 06:56
Default v1612+ [Windows] How to change the workingDir shared folder?
LThomes is on a distinguished road
Hello everyone,
I installed OpenFOAM on Windows and it was working fine, but now, I don't have access to the adimin folder anymore. Since it's the folder shared with the workingDir, I can't access my simulation files.
Is there anyway I could change the folder shared with the workingDir? (For exemple, c:\Users\Myname = workingDir)
Thanks in advance.
LThomes is offline   Reply With Quote
Old   May 18, 2017, 08:39
pgh
Pawan Ghildiyal
pgh is on a distinguished road
HI Thomes
I did not understand the issue exactly . Can you elaborate more ? . You copied tutorial in workingDir i.e inside workingDir say in folder tut which is same as C:\User\thomes\tut
, now you are saying that you cannot access the files in tut . You can provide right to particular user in Windows to have admin right which could solve the issue if i am right in my understanding
pgh is offline   Reply With Quote
Old   May 18, 2017, 09:12
Let me try to explain better:
1. There is a shared folder between the container and Windows. So /.../ofuser/workingDir (something like that) is equal to C:/Users/admin on Windows ;
2. I don't have access to the admin folder, so it would be better to save my simulations in another folder;
3. So, I would like to share another folder with the container, i.e., I would like to set C:/Users/thomes to be the /.../ofuser/workingDir in the container.
Is it more clear?
Old   May 18, 2017, 09:38
pgh
Pawan Ghildiyal
Yes.. Thomes.. It is clear now . I will suggest following
i) Uninstall OpenFOAM and all component
ii) Provide admin right to user i.e Thomes
iii) Now user your login to install OpenFOAM . OpenFOAM installer use the login name
to map the area , so if you user admin acccount , it will map admin area.
I hope , it helps,
Old   May 22, 2017, 08:16
It worked!! Thank you very much.
pgh likes this.
change, folder, shared, windows, workingdir
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
How to change turbulence model in InterFoam Gildeh OpenFOAM Running, Solving & CFD 4 March 28, 2012 12:04
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
