[OpenFOAM.org] Problems to run OpenFOAM 3.0.1 on Mac OS 10.11.4 |
March 24, 2016, 22:29 |
#1 | ||
Rémi Demol
Rep Power: 10 |
I'm a new user of OpenFOAM and I have some issues that I don't find answer. I've install OF on my mac OS 10.11.4 with this tutorial : https://github.com/mrklein/openfoam-...ase-&-Homebrew Everything seems to run perfectly. For instance "cavity" is running. But as soon as I quit my terminal, and reopen it, no command can be found. If I try to do the "cavity" example and run blockMesh, it says 'command not found', even if it worked well before. I try to source again the environnement with the command : Quote:
Thank you for your answers. Rémi D. |
March 25, 2016, 07:51 |
As you can see Code:
... -bash: /Users/remidemol/OpenFOAM/OpenFOAM-3.0.1/bin/foamCleanPath: No such file or directory ... There is https://github.com/mrklein/openfoam-...-configuration guide, which addresses issues of disk mount and environment configuration. |
March 25, 2016, 11:29 |
Rémi Demol
Rep Power: 10 |
Thank you for your answer, I'll try it.
OpenFOAM can't be run in parallel in cluster | sibo | OpenFOAM Running, Solving & CFD | 4 | February 21, 2017 16:29 |
[foam-extend.org] problems with openFoam extend 3.0 installation | AmirBaqa1987 | OpenFOAM Installation | 1 | December 20, 2016 19:17 |
[waves2Foam] Problems compiling with Ubuntu 14.04 and OpenFOAM 3.0.1 | kenrichaiz | OpenFOAM Community Contributions | 4 | December 1, 2016 03:05 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
[OpenFOAM.org] Installing OpenFOAM 2.3.0 on Mac - problems with db48 | Silvester | OpenFOAM Installation | 6 | August 17, 2015 04:01 |
