September 15, 2008, 15:09 |
Hi all,
I'm trying to compi
Michael Rangitsch
Rep Power: 17 |
Hi all,
I'm trying to compile the MRFSimpleFoam application with wmake and run into an error during the load: SOURCE=MRFSimpleFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MRFSimpleFoam.o g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/u091108/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/MRFSimpleFoam.o -L/home/u091108/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \ -lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/u091108/OpenFOAM/u091108-1.5/applications/bin/linux64GccDPOpt/MRFSimpleFoa m /home/u091108/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86 _64-unknown-linux-gnu/4.3.1/../../../../lib64/libstdc++.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/home/u091108/OpenFOAM/u091108-1.5/applications/bin/linux64GccDPOpt/MRFSimpleFo am] Error 1 This is on a Suse 10.1 system. Any ideas why it wouldn't like libstdc++.so ? Thanks! Mike Rangitsch |
Error while compiling icoLagrangian Foam | sara | OpenFOAM Running, Solving & CFD | 32 | February 6, 2013 08:45 |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 00:23 |
FOAM FATAL IO ERROR | msrinath80 | OpenFOAM Running, Solving & CFD | 4 | July 30, 2008 10:06 |
FOAM installation error gcc amp g | hanks | OpenFOAM Installation | 9 | January 26, 2006 14:14 |
FOAM FATAL IO ERROR | sita | OpenFOAM Running, Solving & CFD | 2 | August 23, 2005 04:37 |
