OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit
Old   March 25, 2013, 18:10
Unhappy OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit
David Long
keepfit is on a distinguished road
hi, Foamers,
I have been using OpenFOAM 2.1.1 for a while, now I wanna install OpenFOAM on a thinkpad x200 laptop.
So far I tried:
1) Fresh installed Ubuntu 12.10 64bit
Both OF 2.1.1 and OF 2.2.0 compilation failed according to the following installation guide:
http://openfoamwiki.net/index.php/In...M-2.1.1/Ubuntu
and
http://www.openfoam.org/download/source.php
2) So I removed the latest Ubuntu 12.10 system and replaced it with the Ubuntu 12.04.2 LTS (x64), which is same as the OS of my Desktop PC in which OF 2.1.1 is already installed from source pack
here is the first error for OF 2.2.0 compilation:
wmake libso mpi
/usr/bin/ld: error: --add-needed is not supported but is required for libdl.so.2 in /home/dao/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc/openmpi-1.6.3/lib64/libmpi.so
collect2: ld returned 1 exit status
make: *** [/home/dao/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/openmpi-1.6.3/libPstream.so] Error 1
+ OSspecific/POSIX/Allwmake
'/home/dao/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOSspecific.o' is up to date.
Should I change the "linux64Gcc" rules for c/c++, because there are a lot of "/usr/bin/ld: error:....... " errors.
Any hints or recommendation will be appreciated.
Greetings!
keepfit is offline   Reply With Quote
Old   March 26, 2013, 08:31
Adhiraj
adhiraj is on a distinguished road
Are you using gcc 4.7?
I had to add the flag "-fpermissive" to the file wmake/rules/linux64Gcc/c++.
c++FLAGS    = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -fpermissive
This was for OpenFOAM 1.7.1, so may be a bit different from 2.x.x though.
This was in Ubuntu 12.10 64 bit.
adhiraj is offline   Reply With Quote
Old   March 26, 2013, 09:43
David Long
I reinstalled Ubuntu 12.04 LTS again!
but this time I just update the system and then Install OF without installing any other software.
Hoping it works.
PS: the gcc version is 4.6.3.
compilation error, source code, ubuntu 12.04
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 20:42
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
