OpenFOAM-2.2.2 installation failed on Mavericks
Old   January 11, 2014, 20:06
Default OpenFOAM-2.2.2 installation failed on Mavericks
vdr
vdr2 is on a distinguished road
I tried following the steps listed on this page but got errors. I have a feeling I am missing either some needed modules or my path is wrong. I am attaching the first few occurences of the error as it keeps repeating and the size of the complete log file is 275mb. Hope some one ran into a similar issue. Any help is appreciated.
- VDR
vdr2 is offline   Reply With Quote
Old   January 12, 2014, 04:32
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It seems that you have got a problem with gcc installation according to log file. Can you compile something simple with it? Something like:
#include <iostream>
#include <string>
int main(int argc, char* argv[])
    std::string msg = "Hello, World!";
    std::cout << msg << std::endl;
Also on Mavericks you can compile OpenFOAM using clang which comes with Xcode, though you'll need another set of patches. Brief guide can be found here.
alexeym is offline   Reply With Quote
Old   January 13, 2014, 21:03
vdr
Thanks a lot! I have tested the gcc installation is fine.
I would rather use clang if possible. One thing I see in your clang instructions - what is the equivalent of the gcc-mp to be used? Should I still use gcc-mp? Shouldn't there be a clang equivalent of it?
I still the same errors if I use gcc-mp.
-VDR
Old   January 13, 2014, 21:29
vdr
Even when I use clang as the default compiler for all I get the same error. I just noticed that I get an additional error that it cannot find mpicc. Unfortunately mpicc is not available through macports. Is mpicc the same as clang?
Also the errors start happening when the compilation for PStream starts. Until then it goes through fine. Here is the error again -
+ wmakePrintBuild -check
no git description found
+ /bin/rm -f OpenFOAM/Make/darwinIntel64ClangDPOpt/global.C
+ wmakeLnInclude OpenFOAM
+ wmakeLnInclude OSspecific/POSIX
+ Pstream/Allwmake
+ wmake libso dummy
SOURCE=UPstream.C ; clang++ -m64 -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -Wno-overloaded-virtual -Wno-unused-comparison -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -IMYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -IMYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64ClangDPOpt/UPstream.o
In file included from UPstream.C:26:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UPstream.H:43:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/labelList.H:47:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/label.H:61:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/int.H:39:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/word.H:42:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/string.H:51:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/string:430:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/iosfwd:90:
In file included from MYHOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/wchar.h:42:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/cwchar:118:9: error: no member named 'mbstate_t' in the global namespace
using ::mbstate_t;
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/cwchar:120:9: error: no member named 'tm' in the global namespace
using ::tm;
Old   January 14, 2014, 02:21
Alexey Matveichev
Well,
- It should be not just clang but clang++ as you're compiling C++ code.
- Why do you need gcc-mp for clang build?
- To get mpicc you need MPI libraries, so you can a) use 'export WM_MPLIB=OPENMPI' in etc/bashrc and OpenMPI from ThirdParty folder will be built, b) install OpenMPI yourself and use 'export WM_MPLIB=SYSTEMOPENMPI' to use installed version.
- When you install OpenMPI using Macports the name of compiler wrapper is openmpicc. IIRC in patches by Bernhard Gschaider he uses that name.
About your last error: is it clean build? Or maybe you are trying to mix gcc and clang builds and it messes up include paths.
Old   January 14, 2014, 10:23
vdr
Thanks Alexey
I am already all the things you mentioned, except one.
I meant to say the clang eco system of tools in Mavericks not clang the tool specifically. I am using clang++.
I asked that question because I had to configure that (set an env variable) in addition to gcc with the previous instructions.
I already installed openmpi and have set the WM_MPLIB variable to SYSTEMOPENMPI. I see that the build is picking it up.
I did not know (guess) mpicc is openmpicc. After making a symbolic link to it in the bin directory in OpenFoam it picks it up. So went past that.
I suspect this too. Can you send me the options to clang++ when you compile UPstream.C file in your environment? I can compare with the ones I am seeing and then fix the build myself.
Here is what I am seeing --
SOURCE=UPstream.C ; clang++ -m64 -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -Wno-overloaded-virtual -Wno-unused-comparison -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/HOME/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/HOME/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64ClangDPOpt/UPstream.o
Now can you send me the command you see being run in your successful build?
Thanks a lot for your help.
Old   January 14, 2014, 16:20
Alexey Matveichev
I've tried to reproduce your error so I've decided to go from the very beginning - from creation of disk image. And I was able to reproduce your compilation error
In file included from /Users/alexey/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/string.H:51:
In file included from /Users/alexey/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/wchar.h:42:
using ::mbstate_t;
only when I've created (by accident) disk image with case insensitive file system. Are you sure your disk image has case sensitive file system?
And answering your question, here is the line from build log file for compilation of UPStream.C:
no-overloaded-virtual -Wno-unused-comparison -O3  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/alexey/OpenFOAM/Open
FOAM-2.2.2/src/OpenFOAM/lnInclude -I/Users/alexey/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE
Old   January 16, 2014, 10:05
vdr
That was it. The image I created was not case sensitive.
Sadly, I learned that I cannot follow simple instructions in English! Thanks for your help. It compiles without any issues. One thing (I think you mentioned it in your instructions) if you use homebrew you don't even need to change the etc/bashrc file.
Old   January 16, 2014, 11:28
Alexey Matveichev
Actually, if you won't modify etc/bashrc after applying patches, you will be using OpenMPI from ThirdParty folder (and in this case, I guess, you don't need even Homebrew). If you, for example, would like to use Homebrew installed OpenMPI you need to change "export WM_MPLIB=OPENMPI" to "export WM_MPLIB=SYSTEMOPENMPI".
OpenFOAM solvers not able to run in parallel raagh77 OpenFOAM Installation 5 November 27, 2013 17:05
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
Source Pack Installation OpenFOAM Version 2.1.0 on Redhat Linux Indrajit OpenFOAM Installation 1 April 1, 2012 04:39
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
