[swak4Foam] Problem compiling simpleFunctionObjects library |
June 3, 2014, 11:23 |
Luca
Rep Power: 15 |
Dear All,
I have downloaded the simpleFunctionObjects according to the link provided here: http://openfoamwiki.net/index.php/Co...unctionObjects I have it in my home directory and following the README file I used the following command to compile it: Code:
wmake libso Code:
linux64GccDPOpt/options:6: linux64GccDPOpt/../../../rules/versionOptions: No such file or directory make: *** No rule to make target `linux64GccDPOpt/../../../rules/versionOptions'. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/luca/OpenFOAM/luca-2.3.0/applications/utilities/simpleFunctionObjects Can somebody help me? Thank you in advance, Luca |
June 3, 2014, 16:43 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
TL;DR: install swak. Sorry
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 3, 2014, 17:23 |
Luca
Rep Power: 15 |
Dear Bernhard,
thank you very much for your reply. I will follow your hint and install swak. Hope it works. Thank you and regards, Luca |
of 2.3, simplefunctionobjects |
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) | Ali.beh | Fluent UDF and Scheme Programming | 3 | August 27, 2018 04:22 |
problem during compiling UDF | ned.musab | Fluent UDF and Scheme Programming | 1 | October 11, 2017 10:48 |
Compiling an external Fortran library of thermodynamics and using inside reactingFoam | Mehdi3031 | OpenFOAM Programming & Development | 4 | March 18, 2016 18:10 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
Problem with compiling the WAVE.C (UDF) | raghu mohan | Fluent UDF and Scheme Programming | 4 | November 25, 2011 14:09 |
