[OpenFOAM.com] starting problem on mac: "xhost: command not found" |
May 6, 2016, 09:51 |
#21 |
Evan
Rep Power: 9 |
[root@eba8e7f5a175 cavity]# echo $FOAM_RUN
/root/OpenFOAM/ofuser-v3.0+/run [ofuser@eba8e7f5a175 cavity]$ echo $FOAM_RUN /home/ofuser/OpenFOAM/ofuser-v3.0+/run ...It worked? I'm sorry for the confusion I literally don't know why its working all of a sudden. |
May 6, 2016, 09:54 |
#22 |
Evan
Rep Power: 9 |
It seems to have happened when I downloaded the new version of virtual box
May 6, 2016, 10:08 |
#23 |
Pawan Ghildiyal
Rep Power: 10 |
Launch docker terminal box i)delete old container by running following command "docker rm -f of_v3.0_plus"
ii) run this command "docker ps -a " to see there is no container now iii) unzip the latest script that i have provided and put in /C/Users and use this command docker-machine ssh default $HOME/installOpenFOAM_MAC_pgh $HOME You will be login as docker (There is no ofuser involved in it) then follow rest of instruction |
May 6, 2016, 10:41 |
#24 |
Evan
Rep Power: 9 |
Here's what happened when I followed your last comment.
taylor:~ myusername$ ./startOpenFoam+_MAC of_v3.0_plus bash-4.1$ whoami whoami: cannot find name for user ID 1000 bash-4.1$ mkdir -p $FOAM_RUN bash-4.1$ run //so it was able to make the directory bash-4.1$ export DISPLAY=my.ip bash-4.1$ export LIBGL_ALWAYS_INDIRECT=y bash-4.1$ paraFoam Created temporary 'cavity.OpenFOAM' paraview: cannot connect to X server my.ip But it couldn't open the graphical interface like before for some reason |
May 6, 2016, 10:49 |
#25 |
Pawan Ghildiyal
Rep Power: 10 |
I am not using paraFOAM from docker container. I will suggest to download paraview seprately for MAC and then work on it .
http://www.paraview.org/download/ Also did you add display variable as suggested earlier in your command i.e in script (Note just need to add -e DISPLAY=${displayVar} in script . and rerun it after deleting old container docker run -ti .... -e DISPLAY=${displayVar} --workdir |
May 6, 2016, 11:14 |
#26 |
Evan
Rep Power: 9 |
I've now installed paraview and made the change to the script. My script reads:
docker run -it -d --name ${containerName} --user=${user} -e USER=${username} -e DISPLAY=${displayVar} --workdir -e QT_X11_NO_MITSHM=1 -e HOME=/home/docker/Users --workdir="/home/docker/Users" --volume="${home}:/home/docker/Users" -v=/tmp/.X11-unix:/tmp/.X11-unix ${imageName} /bin/bash --rcfile /opt/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc However now I can't even run the container: taylor:~ myusername$ ./startOpenFOAM+_MAC Error response from daemon: No such container: of_v3.0_plus Error: failed to start containers: of_v3.0_plus Error: No such container: of_v3.0_plus |
May 6, 2016, 11:31 |
#27 |
Pawan Ghildiyal
Rep Power: 10 |
remove --workDir that is highlightred above |
May 6, 2016, 12:01 |
#28 |
Evan
Rep Power: 9 |
Andd we have lift off! Thank you my friend, I am now running programs as user1000 and not as root
May 7, 2016, 14:58 |
#29 |
Florida
Rep Power: 10 |
Dear ugh,
I am back again, I used your latest script but I get the password incorrect. See below: Merons-MacBook-Pro:~ ban$ ./startOpenFOAM+ of_v3.0_plus bash-4.1$ su user su: user user does not exist bash-4.1$ su ofuser Password: su: incorrect password bash-4.1$ I used the password ofuser2015 and Ofuser2015. Both did not work. When I used the latest attached script I do not need to change users "Name". any clue? thanks, Azaria |
May 7, 2016, 15:39 |
#30 |
Pawan Ghildiyal
Rep Power: 10 |
Hi Azaria
1)Before launching script, make sure to run command docker rm -f of_v3.0_plus to make sure you have deleted old container. 2. )please note that with latest script you do not need to login as ofuser.. 3) command "echo $USER", will throw user name as docker.. check this please 4) run this command "mkdir -p $FOAM_RUN" and see whether there is permission issue . 5)Login as root ie su root and use password 0fuser2015 ... |
May 8, 2016, 11:13 |
#31 |
Florida
Rep Power: 10 |
Dear pgh,
I have run the cavity tutorial successfully. Thank you so much. Azaria |
May 13, 2017, 18:26 |
#32 |
Rep Power: 8 |
Hi Pawan,
I am new to OpenFoam. I installed OPENFOAM for windows-v1612+. I am trying to run the first tutorial. I am in workingDir but when I enter" cp -ar $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity ." I receive the error of permission denied. Please advise. Thanks |
May 14, 2017, 22:32 |
#33 |
Rep Power: 8 |
I finally solved the issue. uninstall the whole thing, activate windows module installer, check for updates for windows and reinstall the openFoam and the problem resolved.
big difference between clockTime and executionTime | LM4112 | OpenFOAM Running, Solving & CFD | 21 | February 15, 2019 03:05 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
