[OpenFOAM.com] v1606+ flag provided but not defined: --privileged |
August 23, 2016, 14:16 |
Hello
i installed openfoam using the windows installer I am trying to run OpenFOAM_Start, after I ran OF_Env_Create as the installation guide says, i get the next error message (windows 7 64 bit), any advices? Thanks! C:\Program Files (x86)\ESI\OpenFOAM\1606>"C:\Program Files (x86)\ESI\OpenFOAM\16 06\Windows\Scripts\of_start_container.exe" -Arguments "C:\Program Files\Docker T oolbox\;C:\Program Files\Git\bin" Starting "default"... (default) Check network to re-create if needed... (default) Waiting for an IP... Machine "default" was started. Waiting for SSH to be available... Detecting the provisioner... Started machines may have new IP addresses. You may need to re-run the `docker-m achine env` command. of_plus_1606 flag provided but not defined: --privileged See 'C:\Program Files\Boot2Docker for Windows\docker.exe exec --help'. Stopping "default"... |
September 19, 2016, 05:34 |
Pawan Ghildiyal
Rep Power: 10 |
Hi.. You still facing the issue ?
September 21, 2016, 16:36 |
I have the exact same problem....
September 30, 2016, 19:05 |
[OpenFOAM plus][v1606+] Problems installing on windows 10
rob cooper
So i'm installing for the first time on windows 10. I followed the OF_Windows_Guide_V1606+.pdf, and it says to enable hardware assisted virtualization. I scoured my BIOS, but didn't find this option. Also I looked through task manager but didn't see anything obvious... in the guide it says "In Windows8, and Windows10 it can be checked via the Task Manager.", how is that done? When i try to run OpenFOAM_Start, i get (see attached OpenFOAM_Start.png) then the command window closes and nothing happens. My motherboard is about 5 years old, maybe I need newer hardware? thanks, rob |
September 30, 2016, 19:21 |
rob cooper
In System Information, it says "Hyper-V - Virtualization Enabled in Firmware Yes". Is that the same thing as "Hardware assisted virtualization"?
October 6, 2016, 02:55 |
Rep Power: 14 |
I have exactly the same problem although virtualization is enabled. I think the Problem comes from something else, anyone having this issue and solved this ? Thanks |
October 19, 2016, 06:38 |
Pawan Ghildiyal
Rep Power: 10 |
Hi Rob
Are you manage to solve the issue ? Regards Pawan |
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
UDF link fortran source | yorelchr | Fluent UDF and Scheme Programming | 0 | February 7, 2013 03:44 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
