August 26, 2005, 15:47 |
There are two environment vari
Maka Mohu
Rep Power: 18 |
There are two environment variables that point to wrong folder names after installation, which result in problems with either foamInstallation test or just running the FoamX since the test is not updated:
$JAVA_PATH points to $HOME/OpenFOAM/linux/j2sdk1.4.2_05 while it should point to linuxAMD64 since this is the name for <platform> $MICO_ARCH_PATH -bash: $HOME/OpenFOAM/OpenFOAM-1.2/src/mico-2.3.11/platforms/linuxGcc4Opt where it should point to linuxAMD64GccOpt the last folder name convention (linuxGcc4Opt) is used correctly in the rest of environment variables, like: $FOAM_LIBBIN $FOAM_USER_LIBBIN $LAM_ARCH_PATH so why the unpacking added this AMD64 to the normal linuxGCC4Opt in one place but not all. correcting such names by changing folder names, does not remove the 2 critical errors. foamInstallationTest gives 2 critical error(s) By the way I read the thread: OpenFoam-Bugs: Typo in foamInstallationTest, version 1.2? and the suggested modification does not solve the problem for 64 bit installation. the result of the test is: ---------------------------------------------------------------- $JAVA_PATH ...mhussin/OpenFOAM/linux/j2sdk1.4.2_05 no no $MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt no yes gcc ...figure WARNING: Conflicting installations: foam settings: /home/mhussin/OpenFOAM/linux/gcc-4.0.1/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2-01 WARNING: Conflicting installations: foam settings: /home/mhussin/OpenFOAM/linux/j2sdk1.4.2_05/bin/java current path : /opt/blackdown-jdk-1.4.2.01/bin/java head: `-1' option is obsolete; use `-n 1' since this will be removed in the future gzip 1.3.5 /bin/gzip tar 1.3.5 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ----------------------------------------------------------------- Can any body help? /Maka |
August 26, 2005, 16:14 |
problem solved.
it is a techn
Maka Mohu
Rep Power: 18 |
problem solved.
it is a technical problem, the 64 bit cluster has 32 bit processor on the file server so, I had to ssh to one of cluster processors to install. it seem that it is good to check $processor before installing: 32 bit gives i686 64 bit gives x86_64 |
October 20, 2006, 03:57 |
Dear Maka Mohu,
I am tryin
Dear Maka Mohu,
I am trying to install OpenFOAM on my computer (Linux Suse 10.1) and I have the same problems as you. Could you please give me some detailed advise how to solve this problem? the result of the test is: ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.0 WARNING: Conflicting installations: foam settings: /home/margst/OpenFOAM/linux/gcc-4.1.0-64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2_11 WARNING: Conflicting installations: foam settings: /home/margst/OpenFOAM/linux/j2sdk1.4.2_05/bin/java current path : /usr/bin/java gzip 1.3.5 /usr/bin/gzip tar 1.3.5 /bin/tar icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam ------------------------------------------------------------------------------- /Rita |
October 20, 2006, 05:19 |
What worked for me is:
In t
Maka Mohu
Rep Power: 18 |
In the following check the <platform> folder name. - This is tried with OpenFOAM V1.2 - It happens that my 64 bit processors are AMD but if I understood right the following may work for you: what is meant by plateform directory is: "linux" for 32 bit "linuxAMD64" for 64 bit so: - make a directory named OpenFOAM in your user folder. - make another directory inside the later and name it, in 64 bit case, linuxAMD64, - copy the following to OpenFOAM: Source pack OpenFOAM-1.2.General.gtgz binary pack OpenFOAM-1.2.linuxAMD64Gcc4Opt.gtgz - unpack with tar xzf - copy the rest of the files to linuxAMD64 - unpack with tar xzf - modify .bashrc - use the following command: export WM_64="on" - you may check you environment vars by: printenv|sort - source from a 64 bit processor since processor type is automatically detected. - After that it worked for me. Good luck! best regards, Maka |
December 3, 2008, 18:31 |
I'm trying to install OpenFOAM
Rishi .
Rep Power: 17 |
I'm trying to install OpenFOAM-1.5 on AMD Opteron (64bit) machine with SuSE SLED 10.
Although the installation test says everything OK, I have problems when I try to build paraFoam. error msg is: File format not recognized. Can somebody throw some light on the issue ? is it some BIG endian issue? Here are the error msg: ************************************************** ************************* the versions of diff installed programs are ************************************************** ************************* QMake version 2.01a Using Qt version 4.3.2 in /usr/local/Trolltech/Qt-4.3.2/lib cmake version 2.4-patch 6 gcc (GCC) 4.3.1 ************************************************** ************************* buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- broken CMake Error: The C compiler "/home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build gmake[1]: Entering directory `/home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp' /home/cfd2/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -E cmake_progress_report /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/C MakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/C MakeTmp/testCCompiler.c Linking C executable cmTryCompileExec /home/cfd2/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -P CMakeFiles/cmTryCompileExec.dir/cmake_clean_target.cmake /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -fPIC "CMakeFiles/cmTryCompileExec.dir/testCCompiler.o" -o cmTryCompileExec -rdynamic /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64 -unknown-linux-gnu/4.3.1/../../../../lib64/libgcc_s.so: file not recognized: File format not recognized collect2: ld returned 1 exit status gmake[1]: *** [cmTryCompileExec] Error 1 gmake[1]: Leaving directory `/home/cfd2/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/ CMakeTmp' gmake: *** [cmTryCompileExec/fast] Error 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** No targets specified and no makefile found. Stop. done ************************************************** ************************* Compiling a simple helloworld.cpp to check gcc ************************************************** ************************* #include <iostream> using namespace std; int main() { cout << " Hello World "<< endl; return 0; } ******************** gcc helloworld.cpp /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64 -unknown-linux-gnu/4.3.1/../../../../lib64/libgcc_s.so: file not recognized: File format not recognized collect2: ld returned 1 exit status ************************************************** ************************* ThirdParty > ./Allwmake ... ... ... /home/cfd2/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64 -unknown-linux-gnu/4.3.1/../../../../lib64/libstdc++.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/home/cfd2/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libMGridGen.so] Error 1 ************************************************** ************************* |
January 10, 2009, 12:56 |
I use OpenFOAM 1.4.1 with
Danielle PRL
Rep Power: 17 |
I use OpenFOAM 1.4.1 with Open suse 11. I have installed all the package Tcl/tk but paraFoam gives this error: /home/danprlx/OpenFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/paraview-real: error while loading shared libraries: libtk8.4.so: cannot open shared object file: No such file or directory I need a help thanks |
January 11, 2009, 00:36 |
Hi Danielle,
can you send
Velan
Rep Power: 17 |
Hi Danielle,
can you send us the output of locate libtk8.4.so ? This error shows, that libtk8.4.so is not installed or path is not defined properly. If locate doesnt shows any output, then you have to install libtk8.4.so, If it shows the path, then try to export that path and rebuild it. It will work properly. |
January 11, 2009, 10:42 |
The reason is that you are try
Hua Zen
Rep Power: 17 |
The reason is that you are trying to use an old package file (libtk8.4.so) in a new OS(suse 11). You should install it.
Regarding installation | vidyaprakash | Siemens | 0 | December 21, 2006 23:03 |
HP Installation | ali | OpenFOAM Installation | 7 | August 18, 2005 16:28 |
installation | mohammad | FLUENT | 0 | May 4, 2003 10:15 |
NT 4.0 installation | peter.liang | Siemens | 2 | July 4, 2001 12:52 |
HP-UX installation | new here | FLUENT | 1 | October 26, 2000 21:54 |
