OpenFOAM 14 for WindowstmCygwin
Old   June 13, 2007, 11:49
Default Greetings all! OpenFOAM 1.4
Petr Vita
pvita is on a distinguished road
Send a message via MSN to pvita Send a message via Skype™ to pvita
Greetings all!
OpenFOAM 1.4 basis is successfully ported on Windows(tm)/Cygwin platform. You can download whole port from OpenFOAM Extensions project, tab Downloads, hosted on SourceForge.net. Check this website for future Cygwin port releases.
Package OpenFOAM-1.4-1.cygwin.src.tar.bz2 is a source distribution that compiles without problems under Cygwin. It is a case-insensitive distribution, you can directly unpack it onto Windows file system. Read carefully a README.Cygwin before you start, please. I won't support anybody who has problems 'cause of his inability to read that file.
Package gcc-4.1.2-cygwin.i686.tar.bz2 contains binaries of a GNU GCC compiler, that is compiled with all necessary configuration switches. Do not use GNU GCC distributed with Cygwin, your OpenFOAM won't work with it.
Unported futures at this very moment are FoamX, patchTool and parallel stuff. Further porting work is in progress and concentrates exactly on the missing futures.
Your feedback and bug reports are welcome.
With best regards,
PV
pvita is offline   Reply With Quote
Old   June 13, 2007, 22:39
Default Thanks, Good job! Although I
Qiang Li
frank is on a distinguished road
Thanks, Good job!
Although I usually run it on SuSE, it's still wonderful work for the ALL users, it is an alternative.
LQ
frank is offline   Reply With Quote
Old   June 14, 2007, 09:37
Default Thanks for a great work! Wh
Takuya OSHIMA
7islands is on a distinguished road
When I tried building the port on a 1 GBytes machine, linking libfiniteVolume.dll failed due to, guess what, out of memory. Observation with the task manager after allocating 2 GBytes (it was a VM on Linux) revealed the process to take about 820 MBytes, so those who try building the beast might want to have enough RAM space.
Other than that compilation seems to have finished without noticable trouble. Again, thanks for an impressive porting work.
Takuya
7islands is offline   Reply With Quote
Old   June 14, 2007, 10:02
Default I have similar problem try to
Dmitry Skiba
dimka is on a distinguished road
I have similar problem try to use in linking stage -Wl,--large-address-aware you will get 2048Mb per process
dimka is offline   Reply With Quote
Old   June 14, 2007, 10:11
Default I compiled whole OpenFOAM-1.4-
Petr Vita
I compiled whole OpenFOAM-1.4-1.cygwin.src.tar.bz2 distro on a native Windows notebook with 1GB RAM only during Zagreb workshop. Could it be related to VM on Linux?
PV
Old   June 14, 2007, 10:21
Default Or might be because of using a
Takuya OSHIMA
Or might be because of using a localized (Japanese) version of Windows (Japanese version is said to take a lot more RAM than English version).
T.
Old   June 15, 2007, 10:31
Default Greetings! I am not sure if
Petr Vita
Greetings!
I am not sure if it is normal to make a new release 2 days after 1st one, but well, things happens.
Therefore, I proudly announce new Cygwin port release OpenFOAM-1.4-2.cygwin.src.tar.gz, you can download from OpenFOAM Extensions project.
What is so new to make it up for a new release? Parallelization and tons of small scripts shavings and polishes! You are getting historically the first Cygwin port that is coming with parallel computations based on LAM/MPI. I successfully ran a tutorial example damBreak balanced on 2 processors of my old good Intel Pentium CPU with HyperThreading under Windows. And no, I am not going to make screenshots for you, do them yourself.
Port compiles, straight of package, into a non-parallel version, you have to just uncomment WM_MPLIB variable in bashrc file. Rest is a cake as usual.
Nice Weekend!
PV
PS: You who are unsure what Windows/Cygwin is and if it is good for you, visit Cygwin Website first, please.
PS2: For those who cannot get README.Cygwin out of an archive to read it, here it is attached for you. You can as well use bunzip2 followed by tar to unpack it yourself.
README.Cygwin
Old   August 7, 2007, 05:22
Default Hi Petr and OpenFOAM extension
Takuya OSHIMA
Hi Petr and OpenFOAM extensions people,
Now that I finished the porting work of FoamX/patchTool/"paraFoam via native reader" over the OpenFOAM-1.4-2.cygwin release, I'm attaching the patch. I think it'd be nice if the patch is included in the cygwin port distribution.
In fact, this time Petr and I have agreed beforehand to include FoamX-patch in the Cygwin port of OpenFOAM upon completion, so I sent the patch to Petr twice but currently I have no response. Could anyone in OpenFOAM extensions project contact him?
Of course anyone who's intersted in the patch can try it, and I'd be glad to hear how it works or not.
Note:
1. Before applying the patch you need to pull mico-2.3.12 distribution from the official OpenFOAM-1.4 source tarball or from MICO website http://www.mico.org and place it under OpenFOAM-1.4/src.
2. There's not so much to mention technically because the patch basically carries over the work from 1.3. One exception, however, is that now you don't have to set JAVA_HOME manually - the initialization script looks for the newest JDK under the %PROGRAMFILES%\Java directory (usually C:\Program Files\Java).
Takuya
FoamX-cygwin-20070723.diff.gz
Old   August 7, 2007, 05:36
Default Hi, Here's another patch ag
Takuya OSHIMA
Here's another patch again for OpenFOAM-1.4-2.cygwin. This is a collection of fixes for whatever I noticed while using but not related to FoamX-stuff.
The patch includes
* fix to ccm26ToFoam building problem
* fix to libphaseModel building problem
* porting of some of the scripts under OpenFOAM-1.4/bin (foamInstallationTest etc.)
* slight modifications to Pstream/Allwmake and wmake/makeWmake
* modification to .so loader (dlLibraryTable.C) so that .dll files can be loaded even if a file with .so extension is specified
* workaround for kivaToFoam crash
* dieselFoam/aachenBomb problem reported here.
OpenFOAM-1.4-misc-patch-20070807.diff.gz
Takuya
Old   August 7, 2007, 05:46
Default I forgot to mention the misc p
Takuya OSHIMA
I forgot to mention the misc patch includes fix for Windows Vista (CYGWIN_NT-6.0). Besides, on Vista it seems that you need to run FoamX once from a console with Admin privilege.
Takuya
Old   August 7, 2007, 07:00
Default Hi Takuya! Petr is currentl
  #11
Assistant Moderator
Bernhard Gschaider
Hi Takuya!
Petr is currently not very frequently reading his EMail. I'll tell him to get in touch.
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 7, 2007, 08:56
Default Hi Bernhard, I hope he's fine
  #12
Takuya OSHIMA
Hi Bernhard,
I hope he's fine and just out for vacation - Thanks!
Takuya
Old   August 8, 2007, 05:21
Default Oops, sorry the Vista-fix wasn
  #13
Takuya OSHIMA
Oops, sorry the Vista-fix wasn't actually included. Here's the right one:
OpenFOAM-1.4-misc-patch-20070808.diff.gz
Takuya
Old   August 9, 2007, 05:30
Default Thank you for a patch! I will
  #14
Petr Vita
Thank you for a patch! I will merge it with 1.4-2 release and get it out, as soon as it compiles on my rig.
-- PV
Old   September 18, 2007, 09:30
Default Greetings! I am sorry it to
  #15
Petr Vita
Greetings!
I am sorry it took so long, but my holidays, illness, me being busy and week problems to get the last release up on the SourceForge.net delayed whole long anticipated Cygwin port. Thanks to Takuya Oshima we got now even FoamX and paraFoam working and with that we got all features running on Windows/Cygwin platform. You can download last release OpenFOAM-1.4-3.cygwin.src.tar.bz2 as usual from OpenFOAM Extensions project.
Regarding the release of OpenFOAM 1.4.1, I am skeptic we will port it any soon. Hm. I hope Bernhard won't kick me into it.
Have your fun!
PV
Old   September 30, 2007, 07:31
Default Wow, I just arrived here at Op
  #16
David Meyer
djmeyer is on a distinguished road
Wow, I just arrived here at OpenFOAM and I am impressed with the effort just in this thread!
This port is ideal for me so I will try to install it soon. One question. How will this work on an Intel Core Duo processor? Will this need to use the parallelisation feature to get the most form it?
djmeyer is offline   Reply With Quote
Old   September 30, 2007, 10:19
Default Hello! I would like to know
  #17
N S Prasad
nsp82 is on a distinguished road
Hello!
I would like to know if these cygwin ports will do the job submitted from a linux distro under parallel mode .... ?
Thats coz we have very few linux boxes here and most are windoze. But I sure would like to use those processors ...
Regards.
nsp82 is offline   Reply With Quote
Old   September 30, 2007, 22:59
Default I am having some issues with C
  #18
David Meyer
I am having some issues with Cygwin trying to install OpenFOAM. I am new to Cygwin and not an expert in Linux.
1st. When I run bashrc I get a message saying
ls: cannot access jgk*: No such file or directory
I set the ALT_UNIXCOMMAND_PATH to my jdk directory and I still get the message.
I tried to run Allwmake anyway and it produced a large number of errors such as these.
+ cd wmake
+ ./makeWmake
Makefile:61: /rules//general: No such file or directory
Makefile:62: /rules: No such file or directory
make: *** No rule to make target `/rules'. Stop.
ln: creating symbolic link `Makefile': File exists
ln: creating symbolic link `MakefileFiles': File exists
+ cd src
+ ./Allwmake
+ cd /OpenFOAM
./Allwmake: line 4: cd: /OpenFOAM: No such file or directory
+ wmakeLnInclude .
./Allwmake: line 4: wmakeLnInclude: command not found
+ wmake libso zlib-1.2.1
./Allwmake: line 6: wmake: command not found
+ wmake libso foamUser
./Allwmake: line 7: wmake: command not found
I have installed OpenFOAM in the following directory
/home/David/OpenFOAM/OpenFOAM-1.4.
The jdk is installed in the C:\Program Files\Java\jrockit-R27.3.1-jdk1.6.0_01 directory.
As far as I can work out i have installed all of the additional modules required for OpenFOAM as per the Readme. In additon there were some modules recommended for java that I added.
Any help would be appreciated.
Old   October 1, 2007, 08:09
Default Hi David, @JDK installation:
  #19
Takuya OSHIMA
Hi David,
@JDK installation: in your case you have to set JAVA_HOME to your JDK installation directory manually by editing the line 175 of ~/OpenFOAM/OpenFOAM-1.4/.bashrc, as written in README.Cygwin.
@Allwmake problem: you have to run source ~/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/bashrc before running ./Allwmake.
Takuya
Old   October 2, 2007, 07:38
Default Takuya, Thanks for the help
  #20
David Meyer
Takuya,
Thanks for the help. I don't see anything in the README about editing line 175. I had made JAVA_HOME = ..jdk.. a windows envirnonment variable.
I still get the "ls: cannot access jdk*: No such file or directory" message now.
Does anyone know if running OpenFOAM with cygwin would be better or worse than installing vmware and running it under linux?
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[Other] CAD and openFOAM erik023 OpenFOAM Meshing & Mesh Conversion 2 September 9, 2008 15:27
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
