IcoFoam Not Installed and blockMesh command not found |
June 25, 2008, 16:27 |
Dear Gurus,
I have some pro
Cesar Belaunde Zarate
Rep Power: 17 |
Dear Gurus,
I have some problems when I install OpenFoam-1.3 , I can solved all least one. When I run foamInstallationTest appears the following: Executing /home/cebz/OpenFOAM/OpenFOAM-1.3/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: cebz OS: Linux version 2.6.22.5-31-default User: cebz User_config: /home/cebz/.bashrc Foam_config: /home/cebz/.OpenFOAM-1.3/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/cebz/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/cebz/OpenFOAM/cebz-1.3 yes no $FOAM_JOB_DIR /home/cebz/OpenFOAM/jobControl yes yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/cebz/OpenFOAM/OpenFOAM-1.3 yes yes yes $FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no $FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes $WM_DIR /home/cebz/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/cebz/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes $LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes $FOAM_USER_LIBBIN ...OpenFOAM/cebz-1.3/lib/linuxGcc4DPOpt yes yes no $LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.0 /home/cebz/OpenFOAM/linux/gcc-4.1.0-64/bin/gcc java 1.4.2_05 /home/cebz/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.12 /usr/bin/gzip tar 1.3.12 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_cebz Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. -------------------------------------------------------------------------------- ------ The only Critical Error was whit icoFoam. I am sure that I copy the tutorial directory in the right place, using the command: cebz@cebz:~/OpenFOAM/cebz-1.3/run/tutorials/icoFoam> cp -r OpenFOAM-1.3/tutorials cebz-1.3/run Well, this is whit foamInstallationTest, in the practice (in the terminal) I sow the following. When I type "run", its work, I mean this comand get me in directory run cebz@cebz:~> run cebz@cebz:~/OpenFOAM/cebz-1.3/run> But, wen I go to icoFoam directory and I type "blockMesh . cavity" this append: cebz@cebz:~/OpenFOAM/cebz-1.3/run> cd tutorials/ cebz@cebz:~/OpenFOAM/cebz-1.3/run/tutorials> cd icoFoam/ cebz@cebz:~/OpenFOAM/cebz-1.3/run/tutorials/icoFoam> ls Allclean Allrun cavity cavityClipped cavityGrade elbow resetFixedWallsScr cebz@cebz:~/OpenFOAM/cebz-1.3/run/tutorials/icoFoam> blockMesh . cavity bash: blockMesh: command not found cebz@cebz:~/OpenFOAM/cebz-1.3/run/tutorials/icoFoam> this message "bash: blockMesh: command not found" Say me that may be the bash is not well configured, but when I star the terminal there is messege of bast, it is: Executing: /home/cebz/OpenFOAM/OpenFOAM-1.3/.bashrc Executing: /home/cebz/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/apps/ensightFoam/bashrc Executing: /home/cebz/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/apps/paraview/bashrc cebz@cebz:~> In other and, when I run Paraview, appears a list of errors but the ParaView in self run and I can see the grafic interface. paraFoam . cavity ErrorMessage # Error or warning: ERROR: In ../../../../../paraview-2.4.2/Utilities/VTKClientServer/vtkClientServerInterpret er.cxx, line 866 vtkClientServerInterpreter (0x530180): Cannot find module "libPVFoamReader.so". The following paths were searched: /home/cebz/OpenFOAM/linux/paraview-2.4.2/lib/paraview-2.4 /home/cebz/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/lam-7.1.1 . . . Well, this is my situation, please somebody tell me what can I do to run blockMesh and star using OpenFOAM. |
June 25, 2008, 18:08 |
Hi Cesar!
Out of personal c
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Cesar!
Out of personal curiosity: why are you installing 1.3? (If I do that, it's because of the retro-feeling. The good old days, when men were men and linear solver specifications were lines and not fancy dictionaries. SCNR) For a newcomer I would definitely recommend 1.4.1. It's one year old (==stable) and it's what most people who could help you use Joke aside: you DID try it from a fresh shell? Not the same you preformed the necessary steps in (editing of .bashrc etc) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 26, 2008, 00:30 |
Well, I used OpenFOAM 1.3 for
Rep Power: 17 |
Well, I used OpenFOAM 1.3 for the las 3 year and I never had any problem, so I had a good experience whit this version.
But, in consideration of this installation's problemas I am thinking seriosly in install 1.4.1 version. |
July 3, 2008, 12:02 |
Hi Cesar,
I am afraid I am ha
Mauro Arruda
Hi Cesar,
I am afraid I am having a similar problem trying to run the blockMesh and other applications. The error message is: bash: /home/marruda/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh: No such file or directory Have you managed to get it to work in the meanwhile? Thanks. |
July 3, 2008, 12:36 |
I had a similar problem when I
Anonymous
Rep Power: 17 |
I had a similar problem when I first tried it, but I got it all installed fine after 2 or three attempts. It was normally not following instructions properly, or missing out a step. Someone else has already mentioned it, but the ubuntu openfoam installation guide is quite good. See here:
https://help.ubuntu.com/community/OpenFOAM |
July 3, 2008, 14:07 |
Thanks Adriano.
I have just d
Mauro Arruda
Thanks Adriano.
I have just decided to do the installation again from scratch and it now works. Here's my thread of mistakes: 1. my os is Linux64 (ubuntu 6.10) 2. I first downloaded the linux64 binaries but forgot to set WN_64="on" 3. it didn't work giving me an error message: bash: No such file or directory 4. Then I downloaded the linux32 binaries but the problem persisted ;( 5. started again with the binaries for linux64 but now setting WN_64="on" 6. Now it all seems to work... well at least I can run the tutorials. Thanx for the help ;p |
July 4, 2008, 04:44 |
No problem, Mauro. The WN_64="
Anonymous
Rep Power: 17 |
No problem, Mauro. The WN_64="on" caught me out as well until I found the ubuntu guide. Good luck with the code! :-)
[OpenFOAM] ParaView command not found | joey | ParaView | 12 | January 18, 2021 05:38 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Bash g command not found | mamaly60 | OpenFOAM Installation | 0 | October 18, 2007 17:14 |
Axisymmetric cases Test with blockmesh and icoFoam | frackowi | OpenFOAM Running, Solving & CFD | 2 | July 11, 2007 19:02 |
