Installation Help
Old   June 3, 2007, 14:25
Default Hello, When I try to source
anonymous
sandbox is on a distinguished road
When I try to source the following error occurs..(Note I am logged in as root)
box:/home # . .bashrc
bash:/home/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/bashrc: Permission denied
Could someone please help me resolve this issue?
Thanks in advance
S.
sandbox is offline   Reply With Quote
Old   June 3, 2007, 14:55
Default Hi S, are you trying to do a
Alberto Passalacqua
Hi S,
are you trying to do a multi-user installation? If so, follow these hints http://www.mfix.org/mwiki/index.php/Organise_Your_Work_with_OpenFOAM#Working_Wit h_Central_Installation
If not, put the OpenFOAM directory in /home/your_user_name.
P.S. For your security, don't run anything as root, if not strictly necessary :-)
Regards,
Alberto
Alberto Passalacqua
Old   December 3, 2007, 08:08
Default Hi everybody, I recieve the
Geurts Koen
koen is on a distinguished road
Hi everybody,
I recieve the same error: /home/koen/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc: Permission denied
I installed it as a single user in /home/koen/ and I will only run it from this user account...
...but I used the su to install OpenFOAM in this users directory.
Could this be the cause of the error?
(I am using OpenSuse 10.3)
I hope somebody can help me.
Greetzzz, Koen...
koen is offline   Reply With Quote
Old   December 3, 2007, 08:52
Default To be sure, I just removed the
Geurts Koen
To be sure, I just removed the entire OpenFOAM directory and re-downloaded all files and re-installed it from scratch, now as the user and not superuser.
It still results in the same error:
bash: /home/koen/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc: Permission denied
So know I am realy counting on this forum to help me overcome this problem.
Koen...
Old   December 3, 2007, 09:38
Default Don't try to execute the scrip
Takuya OSHIMA
7islands is on a distinguished road
Don't try to execute the script, but "source" it:
source /home/koen/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
Takuya
7islands is offline   Reply With Quote
Old   December 3, 2007, 09:42
Default I am running on OpenSUSE 10.3
Dominique Turmel
doum is on a distinguished road
I am running on OpenSUSE 10.3 and my .bashrc is the following (username = openfoam), and everything is working fine
. /home/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc
export WM_64=on
doum is offline   Reply With Quote
Old   December 3, 2007, 09:44
Default Hi Koen, First you should see
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Koen,
First you should see what are the prermisions on that file. For that type:
ls -l /home/koen/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
id
The first command should give you, among other things, the permissions set on that file. In my case it reads as following:
-rw-r----- 1 dragosm fsd 7257 2007-10-03 14:15 OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
The second command, will show you the user/group that you actually are logged as. In my case is:
uid=525(dragosm) gid=501(fsd) groups=501(fsd),801(educ),802(ext)
If you fill this is too slow, just mail me on private.
By the way, I have a full instalation of OpenFOAM 1.4.1 that works perfect on OpenSUSE 10.3.
Dragos
dmoroian is offline   Reply With Quote
AMD 64 bit installation maka OpenFOAM Installation 7 January 11, 2009 10:42
Regarding installation vidyaprakash Siemens 0 December 21, 2006 23:03
installation mohammad FLUENT 0 May 4, 2003 10:15
NT 4.0 installation peter.liang Siemens 2 July 4, 2001 12:52
HP-UX installation new here FLUENT 1 October 26, 2000 21:54
