Problem during recompilation using Allawake
Old   October 27, 2007, 11:33
Default I am also not been able to rec
Nishant
nishant_hull is on a distinguished road
I am also not been able to recompile the foam to run it in debug mode. I do not know what exactly is the problem. can any body tell me, is this because of gcc compiler or what?? i have two gcc compiler on my linux system. one default and one with the package. precompiled programs on my ststem is running quite ok. But so far I could not be able to run any own programm.
The error after recompiling using ./Allawake is :-
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::ReleaseDataFlagOn()':
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:116: warning: use of old-style cast
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::ReleaseDataFlagOff()':
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::RequestExactExtentOn()':
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:273: warning: use of old-style cast
/home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::RequestExactExtentOff()':
`/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPDebug/libvtkFoam.so' is up to date.
make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/vtkFoam'
+ cd PVFoamReader
+ mkdir -p Make/linuxGccDPDebug
+ cd Make/linuxGccDPDebug
+ cmake ../..
./Allwmake: line 6: cmake: command not found
+ make
make[3]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug'
make[3]: *** No targets specified and no makefile found. Stop.
make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug'
make[2]: *** [PVFoamReader] Error 2
make[2]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics'
make[1]: *** [graphics] Error 2
make[1]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing'
make: *** [postProcessing] Error 2
+ '[' 0 = 1 -a '' = doc ']'
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   October 27, 2007, 12:32
Default Hi :-)! Check my post regar
Philippose Rajan
philippose will become famous soon enough
Hi :-)!
Check my post regarding this on your post in the category "Running/Solving CFD"
Philippose
philippose is offline   Reply With Quote
[OpenFOAM.com] Recompilation errors MPI related lr103476 OpenFOAM Installation 16 July 7, 2016 21:21
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Why recompilation is necessary nishant_hull OpenFOAM Running, Solving & CFD 6 November 1, 2007 07:22
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
