Compilation error for the development version 13 from the powerlab
Old   August 13, 2007, 16:25
Default Dear OpenFOAM developers and u
jaswi is on a distinguished road
Dear OpenFOAM developers and user
I have been trying to compile the OpenFOAM 1.3 development version.
I have followed the build instruction religiously and it works for the compilation of OpenFOAM 1.4.1 including the compilation of paraview 2.4.4.
When i follow the same steps for the OpenFOAM 1.3 development version I always get stuck with these error
/usr/bin/ld: cannot find -ltermcap
collect2: ld returned 1 exit status
make: *** [/home/singh/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/setSet ] Error 1
In file included from ensightField.H:72,
from foamToEnsight.C:38:
ensightField.C: In function 'void writePatchField(const Foam::word&, const Foam::Field<type>&, const Foam::word&, const Foam::ensightMesh&, const Foam::fileName&, const Foam::word&, Foam::label, Foam:stream&)':
ensightField.C:313: error: no matching function for call to 'Foam:Fstream:Fstream(Foam::fileName&, Foam::IOstream::streamFormat&, Foam::IOstream::versionNumber&, Foam::IOstream::compressionType&)'
/home/singh/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/OFstream.H:109: note: candidates are: Foam:Fstream:Fstream(const Foam::fileName&, std::_Ios_Openmode, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType)
/home/singh/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/OFstream.H:87: note: Foam:Fstream:Fstream(const Foam:Fstream&)
make: *** [Make/linuxAMD64Gcc4DPDebug/foamToEnsight.o] Error 1
FoamXAny.C: At global scope:
FoamXAny.C:564: error: 'void FoamX::operator>(const FoamXServer::FoamXAny&, const FoamXServer::FoamXAny&)' should have been declared inside 'FoamX'
FoamXAny.C:692: error: 'void FoamX::operator<(const FoamXServer::FoamXAny&, const FoamXServer::FoamXAny&)' should have been declared inside 'FoamX'
make: *** [Make/linuxAMD64Gcc4DPDebug/FoamXAny.o] Error 1
make: *** Waiting for unfinished jobs....
/usr/bin/ld: cannot find -lFoamX
make: *** [/home/singh/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/FoamXH ostBrowser] Error 1
make: *** [/home/singh/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/FoamXC aseBrowser] Error 1
make: *** [/home/singh/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxAMD64Gcc4DPDebug/FoamXC aseServer] Error 1
The forum suggested that there is an error related to CMakeLists.txt in the 01-05-2007 version of OF 1.3. but i have already corrected that issue.
Please help me as i badly need this version...
With Best Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   August 13, 2007, 16:52
Default Check http://www.cfd-online.co
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Check http://www.cfd-online.com/OpenFOAM_D.../126/4964.html
msrinath80 is offline   Reply With Quote
Old   August 14, 2007, 02:51
Default Thanks Srinath As I underst
Thanks Srinath
As I understand that solves the first error:
Could you please comment on the other errors:
-->make: *** [Make/linuxAMD64Gcc4DPDebug/foamToEnsight.o] Error 1
--> cannot find -lFoamX
Thanks alot
Jaswinder
Which version is current development line for 15 dkingsley OpenFOAM Installation 20 January 22, 2009 02:49
Which version is current development line for 15 dkingsley OpenFOAM Installation 0 January 12, 2009 08:18
Development version download guillaume OpenFOAM Installation 30 October 15, 2008 00:59
Install development version on Ubuntu hsieh OpenFOAM Installation 9 December 31, 2007 08:18
[OpenFOAM] ParaView patch visualisation error in Development version philippose ParaView 17 March 26, 2007 06:45
