Minor wmake problem for x86_64 when compiling everything using existing gcc WM_COMPILER%3dbb
Old   August 13, 2007, 08:58
Default Description: If you want to
Jason Hoogland
hoogland is on a distinguished road
Description:
If you want to decouple gcc installation/upgrade from OpenFOAM and choose to set WM_COMPILER from 'Gcc' to '' as recommended in $WM_PROJECT_DIR/.OpenFOAM-1.4.1/bashrc, when you go to compile everything using:
$WM_PROJECT_DIR/Allwmake
wmake looks for $WM_PROJECT_DIR/wmake/rules/linux64 thanks to:
RULES = $(WM_DIR)/rules/$(WM_ARCH)$(WM_COMPILER)
in $WM_PROJECT_DIR/wmake/Makefile. $WM_PROJECT_DIR/wmake/rules/linux64Gcc exists, but not linux64.
One fix:
Create a symlink in $WM_PROJECT_DIR/wmake/rules:
ln -s linux64Gcc linux64
hoogland is offline   Reply With Quote
Wmake problem thumthae OpenFOAM Installation 12 December 3, 2008 09:30
Minor buoyancy problem in Phoen2007 patti Phoenics 3 December 1, 2007 18:43
Problem about wmake turbFoam williamscn OpenFOAM Running, Solving & CFD 3 September 19, 2007 11:55
Minor compilation problem with Gcc42 schmidt_d OpenFOAM Bugs 1 May 9, 2007 13:11
Gambit Meshing export to fluent minor problem John c. FLUENT 2 February 6, 2002 16:52
