July 4, 2007, 09:58 |
Hi All
I try to port OpenFO
Josef F. Buergler
Rep Power: 17 |
Hi All
I try to port OpenFOAM-1.4_patch (checked out via svn from sourceforge) onto a Solaris-10 System. Currently I'm using gcc-4.2.0 and binutils-2.17 (both installed in $HOME/OpenFOAM/solaris/). I had some issues with the wmake script, which relys actually on bash, which is different from the Solaris-Shell (/bin/sh), which unfortunately does not know about the "-e" option (file exists). So I would suggest to use "#!/bin/bash" instead of "#!/bin/sh" as the first line in "wmake". Also, "wmake" relys on gnu-find, which knows about the option "-maxdepth"! There is another issues with flex++: In the files - ./src/thermophysicalModels/combustion/Make/options - ./src/thermophysicalModels/combustion/Make/solarisGcc4DPOpt/options I had to add "-I/opt/csw/flex-2.5.33/include" to EXE_INC in order to advice the compiler to find "FlexLexer.h". Currently I'm stuck with the following problem: /home/zabuergl/OpenFOAM/OpenFOAM-1.4/wmake/wmakeLnInclude: linking include files to /CFDData/OpenFOAM/OpenFOAM-1.4/src/LESmodels/incompressible/lnInclude Making dependency list for source file Smagorinsky2/Smagorinsky2.C cmd=make --no-print-directory -j 4 -f /home/zabuergl/OpenFOAM/OpenFOAM-1.4/wmake/Makefile MAKE_DIR=Make INCLUDE_DEPS=Make/solarisGcc4DPOpt/includeDeps libso SOURCE=Smagorinsky2/Smagorinsky2.C ; g++ -Dsolaris -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -O3 -fno-schedule-insns -DNoRepository -ftemplate-depth-30 -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/meshTools/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/LESmodels/LESdeltas/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/LESmodels/LESfilters/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/transportModels -IlnInclude -I. -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/solarisGcc4DPOpt/Smagorinsky2.o Smagorinsky2/Smagorinsky2.C: In member function 'virtual Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::LESmodels::Smagorinsky2::divB(Foam::volVecto rField&) const': Smagorinsky2/Smagorinsky2.C:86: error: no matching function for call to 'laplacian(Foam::volSymmTensorField&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>&)' make: *** [Make/solarisGcc4DPOpt/Smagorinsky2.o] Error 1 I would greatly appreciate any help on this problem! Thanks a lot in advance :-) |
OpenFOAM Solaris | mamaly60 | OpenFOAM Installation | 13 | May 10, 2010 21:16 |
CFX 4.4 on Solaris 9 | Prash | CFX | 0 | February 21, 2005 10:41 |
64-bit Solaris | Steve | Siemens | 4 | April 30, 2004 04:18 |
64-bit Solaris | Steve | FLUENT | 0 | April 28, 2004 04:18 |
CFX & CAD2mesh on Solaris 64-bit | Danie | CFX | 1 | January 22, 2004 16:48 |
