Compiling OpenFOAM14_patch on Solaris 10
Old   July 4, 2007, 09:58
Default Hi All I try to port OpenFO
jfb
Josef F. Buergler
jfb is on a distinguished road
Hi All
I try to port OpenFOAM-1.4_patch (checked out via svn from sourceforge) onto a Solaris-10 System.
Currently I'm using gcc-4.2.0 and binutils-2.17 (both installed in $HOME/OpenFOAM/solaris/).
I had some issues with the wmake script, which relys actually on bash, which is different from the Solaris-Shell
(/bin/sh), which unfortunately does not know about the "-e" option (file exists).
So I would suggest to use "#!/bin/bash" instead of "#!/bin/sh" as the first line in "wmake".
Also, "wmake" relys on gnu-find, which knows about the option "-maxdepth"!
There is another issues with flex++: In the files
- ./src/thermophysicalModels/combustion/Make/options
- ./src/thermophysicalModels/combustion/Make/solarisGcc4DPOpt/options
I had to add "-I/opt/csw/flex-2.5.33/include" to EXE_INC in order to advice the compiler to find "FlexLexer.h".
Currently I'm stuck with the following problem:
/home/zabuergl/OpenFOAM/OpenFOAM-1.4/wmake/wmakeLnInclude: linking include files to /CFDData/OpenFOAM/OpenFOAM-1.4/src/LESmodels/incompressible/lnInclude
Making dependency list for source file Smagorinsky2/Smagorinsky2.C
cmd=make --no-print-directory -j 4 -f /home/zabuergl/OpenFOAM/OpenFOAM-1.4/wmake/Makefile MAKE_DIR=Make INCLUDE_DEPS=Make/solarisGcc4DPOpt/includeDeps libso
SOURCE=Smagorinsky2/Smagorinsky2.C ; g++ -Dsolaris -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -O3 -fno-schedule-insns -DNoRepository -ftemplate-depth-30 -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/meshTools/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/LESmodels/LESdeltas/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/LESmodels/LESfilters/lnInclude -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/transportModels -IlnInclude -I. -I/home/zabuergl/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/solarisGcc4DPOpt/Smagorinsky2.o
Smagorinsky2/Smagorinsky2.C: In member function 'virtual Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::LESmodels::Smagorinsky2::divB(Foam::volVecto rField&) const':
Smagorinsky2/Smagorinsky2.C:86: error: no matching function for call to 'laplacian(Foam::volSymmTensorField&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>&)'
make: *** [Make/solarisGcc4DPOpt/Smagorinsky2.o] Error 1
I would greatly appreciate any help on this problem!
Thanks a lot in advance :-)
jfb is offline   Reply With Quote
Old   July 4, 2007, 12:45
Default Hi Josef, Could you please
Martin Karlsson
martin is on a distinguished road
Hi Josef,
Could you please provide me the gcc-4.2.0 binary for Solaris 10 of yours. I have a few problems to build it my self (I am not root on the Solaris system and root is on vaccation). If I got gcc to work on my Solaris, I will try to port OpenFOAM-1.4_patch as well.
Thanks in advance,
Martin
martin is offline   Reply With Quote
Old   July 4, 2007, 17:17
Default Hi Martin You find the bina
jfb
Josef F. Buergler
Hi Martin
You find the binary version of gcc-4.2.0.tar.gz for Solaris 10 under the following URL
http://iserver.hta.fhz.ch/~jfb/hta/gcc-4.2.0.tar.gz
The correspondings checksums are:
SHA(/tmp/gcc-4.2.0.tar.gz)= 8ed5a1c89e295200863dd1b651a195f53fb1ad1e
RIPEMD160(/tmp/gcc-4.2.0.tar.gz)= 509d2559c41338ddaf8aafb732c0ae302b863e07
SHA1(/tmp/gcc-4.2.0.tar.gz)= f734476d55b4ec74655984fb05df18cbb21c55aa
MD5(/tmp/gcc-4.2.0.tar.gz)= 553ab99f0816d9e0a339026228a0077d
Hope it works for You!
Old   July 5, 2007, 15:21
Default Do not compile Smagorinsky2.C.
Mattijs Janssens
In Make/options replace the C++ style '//' comment with /* ... */
Old   July 5, 2007, 15:22
Default Oops. Should be Make/files. On
Mattijs Janssens
Oops. Should be Make/files. On line 21:
//Smagorinsky2/Smagorinsky2.C
Old   July 9, 2007, 14:15
Default Thanks Mattijs; "//" does not
jfb
Josef F. Buergler
Thanks Mattijs; "//" does not work under Solaris 10!
Unfortunately there are still errors, for example the following:
-fPIC -c $SOURCE -o Make/solarisGcc4DPOpt/decompositionMethod.o
FoamXAny.C:564: error: 'void FoamX::operator>(const FoamXServer::FoamXAny&, const FoamXServer::FoamXAny&)'
should have been declared inside 'FoamX'
FoamXAny.C:692: error: 'void FoamX::operator<(const FoamXServer::FoamXAny&, const FoamXServer::FoamXAny&)'
gmake[2]: *** [Make/solarisGcc4DPOpt/FoamXAny.o] Error 1
Old   July 10, 2007, 13:31
Default This is gcc4.2? Does it work i
Mattijs Janssens
This is gcc4.2? Does it work if you explicitly declare 'operator>' in the FoamX namespace?
FoamXAny.H
Old   July 19, 2007, 10:58
Default Hi Mattijs Your "FoamXAny.H
jfb
Josef F. Buergler
Hi Mattijs
Your "FoamXAny.H" helped to cure the problem. Currently OpenFAOM-1.4 (patched) compiles and works
without parallelization support. Currently I run all the tutorials to find differences with Linux. After that, I try to get the parallelization-stuff working!
If You are interested, I can send a Patchfile to the current release (checked out today via svn).
Old   July 26, 2007, 06:05
Default The following steps describe t
jfb
Josef F. Buergler
The following steps describe the process to port OpenFOAM_1.4 to Solaris10:
1. Install software from blastwave
Basically I had first to make sure, that I have the same environment
on Solaris as on Linux. Therefore I installed some software, i.e. "flex_new",
"bison", "gmake" and "findutils" from http://www.blastwave.org by first
executing the appended shell script ("add_pkg_get.sh") and then typing
some commands (as explained in the shell script and the blastwave site).
2. Install software from scratch
After that I compiled/installed from source
- gcc-4.2.0
- binutils-2.17
- j2sdk1.4.2_14 (Version 14 instead of 5 seems to work)
- java3d-1_3_1
3. Problems with the SHELL
Then I had to replace hardcoded paths to /bin/sh in most of the shell
scripts (Allwmake, etc.), because /bin/sh on Linux is most probably
/bin/bash, whereas on Solaris it is the SUN-Shell, which for example
does not know about "let ..." instead one has to use p=`expr $p + 1`).
4. Problems with GNU/Solaris-commands options
Also grep and find (as well as tar and make) on Solaris use different Options
as the corresponding gnu-Versions! I would suggest, that one should
use something similar to gnu-autoconfigure, etc. in order to find the
correct versions of each of the used commands.
5. Problems with flex-Files
I also had to change some occurences of "]]" to "] ]" in some (f)lex-Files.
6. Patch-File
Attached You will find a patch-file, produced with the following commands
$ cd ~
$ diff -crB OpenFOAM-1.4_patch OpenFOAM_1.4_solaris10 > Solaris10.patch
You should be able to apply it with
$ cd OpenFOAM-1.4_patch
$ patch [--dry-run] -p1 -i Solaris10.patch
7. Adapting compilations rules for Solaris10
For Solaris10, the wmake-rules files are copied with
$ foam
$ cp -r wmake/rules/solaris{Gcc4,}
8. Not everything working yet
I should also mention, that not all tutorial-cases completed successfully
(see attached "testLoopReport_Solaris10_20070725"). Some might not
have completed successfully because of broken parallelization software.
9. Future work
Currently I'm trying to get the parallization software (lam-7.1.3) to run
under Solaris10. Unfortunately, MPI/GAMMA will not run on Solaris10,
because the "someone" would have to rewrite the network-drivers from
anew! What other software package (besides lam-7.1.3) could You suggest
me to use?
I hope this information will be useful to people trying to compile and
install OpenFOAM_1.4 on Solaris 10.
Attached files can be found at http://iserver.hta.fhz.ch/~jfb/Solaris10/
Old   April 16, 2010, 08:58
J. Cai
chiven is on a distinguished road
Hi, Josef, thank you for sharing the precious experience on the installation of OF in Solaris.
Now, I am installing OF-1.6 in Solaris 10 following your suggestions.
The system have installed "flex, bison, and gmake" in /usr/sfw/bin/ directory. Thus I install findutils, gcc, binutils, and java3d in the WM_THIRD_PARTY_DIR directory. Since j2sdk1.4.2_14 is NOT found from internet, I try to replace it with java_ee_sdk-6-unix.sh, but fail, and the following problem is meeting.
HTML Code:
Could not locate a suitable Java runtime.
Please ensure that you have Java 6 or newer installed on your system
and accessible in your PATH or by setting JAVA_HOME
What a pity, I can NOT link to your web page of http://iserver.hta.fhz.ch/~jfb/Solaris10/.
My questions are,
1) Though the softwares are installed and the paths are added to LD_LIBRARY_PATH and PATH, the original shells are still used. For example, when "which find", "/usr/bin/find" still occurs. How to set?
2) When I run the foamSystemCheck script I get the error :
./foamSystemCheck: syntax error at line 56: `NOCHAR=$' unexpected
Maybe many scripts are not able to run on Solaris 10? If yes, how to improve it?
3) Any comments on the java_ee_sdk-6-unix.sh installation?
4) Did you install OF-1.6 in Solaris 10? If yes, would you like to share the experiences to us?
Thank you in advance.
Best regards,
Chiven
chiven is offline   Reply With Quote
OpenFOAM Solaris mamaly60 OpenFOAM Installation 13 May 10, 2010 21:16
CFX 4.4 on Solaris 9 Prash CFX 0 February 21, 2005 10:41
64-bit Solaris Steve Siemens 4 April 30, 2004 04:18
64-bit Solaris Steve FLUENT 0 April 28, 2004 04:18
CFX & CAD2mesh on Solaris 64-bit Danie CFX 1 January 22, 2004 16:48
