Error starting paraFoam line 67 paraview command not found
Old   May 30, 2007, 09:08
Default Hello, I downloaded all pac
Jan Goebel
jango is on a distinguished road
I downloaded all packages I needed and installed them how described. Now I wanted to start with the cavity example in the turorial. FoamX works correctly and all settings can be made, but when I want to start paraFoam to check the generated mesh, as described in the tutorial I get the following error message:
$paraFoam $FOAM_RUN/tutorials/icoFoam cavity
/home/cfduser/OpenFOAM/OpenFOAM-1.4/bin/paraFoam: line 67: paraview: command not found
I guess it is an installation problem...
thank you for your help,
Jan
jango is offline   Reply With Quote
Old   July 18, 2007, 23:12
Default Hi Jan, I am having the sam
William Veale
wbv10 is on a distinguished road
Hi Jan,
I am having the same problem.
Did you find a way to solve this error?
Thanks, Bill
wbv10 is offline   Reply With Quote
Old   July 18, 2007, 23:49
Default Do not know how to solve your
paka is on a distinguished road
Do not know how to solve your problem, but try this in case folder:
touch case_name.foam
then
paraview
and select the "touched" file.
Regards,
K
paka is offline   Reply With Quote
Old   July 19, 2007, 01:03
Default Hi K, Thanks for the respon
William Veale
Hi K,
Thanks for the response.
Typed "touch cavity.foam" in the command line, which worked without a response. Then typing "paraview" brought up the following error:
bash: paraview: command not found
Any thoughts as to where to go next?
Regards, Bill
Old   July 19, 2007, 01:39
Default What does the command 'which p
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
What does the command 'which paraview' return? Have you forgotten to install gcc, java and paraview packages in addition to the OpenFOAM general and platform-specific binary packages? Check out this[1] related thread.
Also, before running anything in OpenFOAM (paraFoam included), you need to source the appropriate bashrc file from the command line as specified in the README:
. $HOME/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/bashrc
[1] http://www.cfd-online.com/OpenFOAM_D...es/1/2002.html
msrinath80 is offline   Reply With Quote
[OpenFOAM] ParaView command not found joey ParaView 12 January 18, 2021 05:38
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Problem running paraFoam paraview command not found spdracer22 OpenFOAM Pre-Processing 2 December 7, 2005 05:32
Starting the CFX-solver from the command line Tony CFX 3 January 3, 2005 15:59
starting from command line? Peter Specht Phoenics 1 August 11, 2003 08:52
