OF 14 Compilation error SuSE 102 64bit
Old   May 9, 2007, 08:00
Default While recompiling OF 1.4 on op
Alberto Passalacqua
While recompiling OF 1.4 on openSUSE 10.2 64 bit, using the compiler provided with OF, I got this error:
make[3]: Leaving directory `/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graph ics/PVFoamReader/vtkFoam'
+ cd PVFoamReader
+ mkdir -p Make/linux64Gcc4DPOpt
+ cd Make/linux64Gcc4DPOpt
+ cmake ../..
-- Check for working C compiler: /home/alberto/OpenFOAM/linux64/gcc-4.1.2/bin/gcc
-- Check for working C compiler: /home/alberto/OpenFOAM/linux64/gcc-4.1.2/bin/gcc -- works
-- Check size of void*
-- Check size of void* - done
-- Check for working CXX compiler: /home/alberto/OpenFOAM/linux64/gcc-4.1.2/bin/g++
-- Check for working CXX compiler: /home/alberto/OpenFOAM/linux64/gcc-4.1.2/bin/g++ -- works
CMake Error: Error in cmake code at
/home/alberto/OpenFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/ParaViewConfig.cm ake:29:
INCLUDE Could not find include file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/platforms/linux64Gcc4DPOpt/Para ViewLibraryDepends.cmake
Current CMake stack: /home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graphi cs/PVFoamReader/PVFoamReader/CMakeLists.txt;/usr/share/cmake/Modules/CMakeCInfor mation.cmake;/usr/share/cmake/Modules/CMakeCXXInformation.cmake;/home/alberto/Op enFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/ParaViewConfig.cmake;/home/dm2/he nry/OpenFOAM/linuxSrc/paraview-2.4.4/platforms/linux64Gcc4DPOpt/ParaViewLibraryD epends.cmake
/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graphi cs/PVFoamReader/PVFoamReader/CMakeLists.txt:38:
INCLUDE Could not find include file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/ParaViewUse.cmake
Current CMake stack: /home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graphi cs/PVFoamReader/PVFoamReader/CMakeLists.txt;/usr/share/cmake/Modules/CMakeCInfor mation.cmake;/usr/share/cmake/Modules/CMakeCXXInformation.cmake;/home/alberto/Op enFOAM/linux64/paraview-2.4.4/lib/paraview-2.4/ParaViewConfig.cmake;/home/dm2/he nry/OpenFOAM/linuxSrc/paraview-2.4.4/ParaViewUse.cmake
/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graphi cs/PVFoamReader/PVFoamReader/CMakeLists.txt:56:
Unknown CMake command "VTK_WRAP_ClientServer".
-- Configuring done
+ make
make[3]: Entering directory `/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/Make/linux64Gcc4DPOpt'
make[3]: *** No targets specified and no makefile found. Stop.
make[3]: Leaving directory `/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/Make/linux64Gcc4DPOpt'
make[2]: *** [PVFoamReader] Error 2
make[2]: Leaving directory `/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing/graph ics'
make[1]: *** [graphics] Error 2
make[1]: Leaving directory `/home/alberto/OpenFOAM/OpenFOAM-1.4/applications/utilities/postProcessing'
make: *** [postProcessing] Error 2
+ '[' 0 = 1 -a '' = doc ']
The compiler looks for files in not existing positions.
Regards,
A.
Alberto Passalacqua
Old   May 9, 2007, 08:10
Default I got the same problem. The Al
Frank Bos
lr103476 is on a distinguished road
I got the same problem. The Allwmake is not present in the solvers and utility directories...
Just compile the utilities and applications that you need by yourself.
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   May 9, 2007, 08:52
Default Hello Frank, I need to recomp
Alberto Passalacqua
Hello Frank,
I need to recompile the whole OF 1.4 due to the bugs in the backward scheme.
Does this mean I've to manually recompile the whole set of utilities and solvers?
Regards,
A.
Alberto Passalacqua
Old   May 9, 2007, 09:01
Default Yes, or you have to write a sc
Frank Bos
Yes, or you have to write a script that executes Allwmake or wmake in every solver / utility subdirectory.....or someone can put the usual scripts here...
Btw, why don't you only recompile the libfiniteVolume.so, since that library included the backward scheme??
Frank
Frank Bos
Old   May 9, 2007, 09:09
Default Thanks Frank, but the PVFoamR
Alberto Passalacqua
Thanks Frank,
but the PVFoamReader utility can't be recompiled anyway because it looks for a file which is not there.
Yes, I'll recompile the libfiniteVolume alone. Forgot this possibility
Regards,
A.
Alberto Passalacqua
Old   May 15, 2007, 03:27
Default to build all subdirectories :
Mattijs Janssens
mattijs is on a distinguished road
to build all subdirectories : wmake all. I put up a page on the OpenFOAM wiki with some more tips about wmake.
mattijs is offline   Reply With Quote
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Compilation error skabilan OpenFOAM Installation 1 September 17, 2007 13:33
Compilation fails on suse linux 101 su_junwei OpenFOAM Bugs 2 July 20, 2007 04:56
Compilation error Rajneesh FLUENT 0 November 11, 2005 16:52
Compile new solver under SuSE 64bit OS hsieh OpenFOAM Running, Solving & CFD 3 September 8, 2005 11:56
