Ubuntu and finding libelfso0
Old   February 20, 2007, 22:55
Default Would someone please point me
Shaun Darmody
shaun is on a distinguished road
Would someone please point me in the correct direction to download and install the libelf.so.0 file so that I may get FoamX to work.
I am only just starting with OpenFOAM and am using Ubuntu 6.06 LTS (Dapper Drake).
Thanks for your help in advance.
Regards
Shaun.D
shaun is offline   Reply With Quote
Old   February 21, 2007, 00:54
Default Well I found the libelf packag
Shaun Darmody
Well I found the libelf package at http://packages.ubuntu.com/dapper/
and then went to install it using Gdebi. Turns out that libelf.so.0 was already installed at usr/lib/libelf.so.0
So, I tried running the command FoamX and still got the same error that everyone else I have noticed on this discussion forum has had in the past. I.e
Starting NameServer with inet:darmodys-desktop:1234 ...
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
So, now I am thinking that somehow FoamX is looking in the wrong directory for this file.
Has anyone had this problem with OpenFOAM in Ubuntu and if so how do you reslove it? My group here in AUS are keen to have OpenFOAM up and running. If needs be, I will reinstall with SUSE if I cannot resolve this issue.
Any help will be much appreciated.
Regards
Shaun.D
Old   April 30, 2007, 04:08
Default I recently installed OpenFOAM
Félix Salazar
orodoni_le is on a distinguished road
I recently installed OpenFOAM 1.4 in Ubuntu 7.04 Feisty Fawn. The installation instructions could be followed with very detail from this sites:
http://ubuntuforums.org/showthread.php?t=156298
https://help.ubuntu.com/community/OpenFOAM
The only difference between sites it's the version number (1.4 in the first and 1.3 in the second). This only affects the filenames on the command line
When I try to run FoamX, received the following error message:
nsd: error while loading shared libraries: libssl.so.0.9.7: cannot open shared object file: No such file or directory
To solve that problem, I simply went to Synaptic, and install the libssl.so.0.9.7 package.
Regards
Felix
PD: Sorry if the help it's late
orodoni_le is offline   Reply With Quote
Old   April 30, 2007, 18:40
Default Thanks for the post Felix. I h
Shaun Darmody
Thanks for the post Felix. I had solved the problem a while ago, and also came across the same issue for OF1.4. I was able to quickly resolve that.
Cheers
Shaun.D
OpenFOAM 13 FoamX libelfso0 and Fedora Core 4 crosby OpenFOAM Pre-Processing 23 June 24, 2008 02:01
FoamX libelfso0 nunoinlux OpenFOAM Bugs 6 September 11, 2007 20:13
Canbt fix libelfso0 proble clo OpenFOAM Installation 3 January 10, 2007 04:17
FoamX libelfso0 mockealm OpenFOAM Installation 6 June 29, 2006 15:37
Sshd amp libelfso0 on gentoo box alfreed OpenFOAM Installation 2 June 15, 2006 10:05
