Gmake install Error 127 ignored
Old   July 25, 2006, 12:44
Default I find only the above error me
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I find only the above error message when I compile OpenFOAM. Can someone kindly point out what could be wrong?
g++ -DlinuxPPC64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -mcpu=power4 -DNoRepository -ftemplate-depth-30
-I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/meshTools/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -shared evaluateError.o -L/home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt -lfiniteVolume -lmeshTools -ldynamicMesh -o /home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt/liberrorEstimation. so
gmake: [install] Error 127 (ignored)
+ wmake estimateScalarError
Making dependency list for source file estimateScalarError.C
SOURCE=estimateScalarError.C ; g++ -DlinuxPPC64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -mcpu=power4 -DNoRepository -ftemplate-depth-30 -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/errorEstimation/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxPPC64Gcc4DPOpt/estimateScalarError.o
/home/madhavan/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /home/madhavan/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxPPC64Gcc4DPOpt/estima teScalarError
msrinath80 is offline   Reply With Quote
Old   July 25, 2006, 12:56
Default Looks strange - it's like gmak
Hrvoje Jasak
Looks strange - it's like gmake failed. Did you get any more messages? Could you go into OpenFOAM-1.3/src/errorEstimation and type wmake libso
Never seen this one before...
Hrv
Hrvoje Jasak
Old   July 25, 2006, 13:03
Default This is what I see: madhava
This is what I see:
madhavan@varese:~/OpenFOAM/OpenFOAM-1.3/src/errorEstimation> wmake libso
make: Nothing to be done for `allFiles'.
make: `lnInclude/uptodate' is up to date.
make: `Make/linuxPPC64Gcc4DPOpt/dependencies' is up to date.
libso
`/home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt/liberrorEstimation .so' is up to date.
Old   July 25, 2006, 13:05
Default Oh, and no more messages. Afte
Oh, and no more messages. After about 6 odd hours, all binaries seem to be in place. I even tried running the cavity case using icoFoam. Works fine. Is the error critical?
Old   July 25, 2006, 13:07
Default Now, I've tried this: madha
madhavan@varese:~/OpenFOAM/OpenFOAM-1.3/src/errorEstimation> wclean && wmake libso
Making dependency list for source file evaluateError/evaluateError.C
libso
SOURCE_DIR=evaluateError
SOURCE=evaluateError/evaluateError.C ; g++ -DlinuxPPC64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -mcpu=power4 -DNoRepository -ftemplate-depth-30 -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/meshTools/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxPPC64Gcc4DPOpt/evaluateError.o
/home/madhavan/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt/liberrorEstimation
rm -f so_locations
cd Make/linuxPPC64Gcc4DPOpt ; \
g++ -DlinuxPPC64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -mcpu=power4 -DNoRepository -ftemplate-depth-30 -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/meshTools/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/home/madhavan/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -shared evaluateError.o -L/home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt -lfiniteVolume -lmeshTools -ldynamicMesh -o /home/madhavan/OpenFOAM/OpenFOAM-1.3/lib/linuxPPC64Gcc4DPOpt/liberrorEstimation. so
Any suggestions?
Old   July 25, 2006, 13:11
Default That looks OK - did it report
Hrvoje Jasak
That looks OK - did it report any errors? BTW, do you really have a space between liberrorEstimation and .so? That looks wrong to me. Have a look at Make/files to see if there's any garbage.
Hrv
Hrvoje Jasak
Old   July 25, 2006, 13:17
Default Oh, no spaces in the actual ou
Oh, no spaces in the actual output. I think it's the forum software again. No errors other than the gmake one. I'm attaching the complete compile log here[1].
Thanks for your help!
[1] http://www.ualberta.ca/~madhavan/compile_log.txt
Old   July 25, 2006, 13:18
Default Oh, and I did not bother about
Oh, and I did not bother about ParaView or FoamX. I just need the solvers/utilities on this machine.
Gambit on Opensuse install error Thiago FLUENT 7 December 14, 2013 07:59
FoamX and paraFoam error after install OpenFoam qtian OpenFOAM Installation 0 February 6, 2008 11:24
Gmake install Error 1 ignored mamaly60 OpenFOAM Installation 0 October 18, 2007 17:16
Strange Install Error Will FLUENT 0 May 2, 2007 14:14
Help: Do I have to install the VC++ for UDF... KE FLUENT 2 August 21, 2003 21:32
