FoamX libelfso0
Old   June 24, 2006, 18:25
Default I have some problems with foam
Marten Almkvist
mockealm is on a distinguished road
I have some problems with foamX
root@pc1:~# FoamX
Starting NameServer with inet:pc1:1234 ...
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
I have tried the following with no suckses.
# cd /usr/lib
# ln -s libelf.so.1 libelf.so.0
I run Slackware
mockealm is offline   Reply With Quote
Old   June 26, 2006, 02:48
Default If you're running a 64bit oper
Francesco Del Citto
fra76 is on a distinguished road
If you're running a 64bit operating system, you can try:
# cd /usr/lib64
fra76 is offline   Reply With Quote
Old   June 26, 2006, 11:11
Default Iam running 32bit
Marten Almkvist
Iam running 32bit
Old   June 28, 2006, 20:06
Default What does the output of the fo
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
What does the output of the following command tell you?
[username@hostname pwd]$ find / -name libelf* -print
msrinath80 is offline   Reply With Quote
Old   June 29, 2006, 11:22
Default thanks, it loiks like this
Marten Almkvist
root@pc1:~# find / -name libelf* -print
/root/libelf.so.0
root@pc1:~#
Old   June 29, 2006, 11:26
Default or root@pc1:~# username@hos
Marten Almkvist
or
root@pc1:~# [username@hostname pwd]$ find / -name libelf* -print
-bash: [username@hostname: command not found
root@pc1:~#
Old   June 29, 2006, 15:37
Default 1. You are certainly new to th
1. You are certainly new to the *nix world. I understand that. Nothing wrong, we've all been there.
2. First advice: Stop working as root user. The root user is much more powerful than the standard windows Administrator. So please stop using it. Create a normal user using the appropriate GUI tool.
3. Copying libelf.so.0 to the /root direcotory is not going to help in any way.
4. OpenFOAM will look for libelf.so.0 in the system lib directory (usually /usr/lib or /usr/lib64 depending on the architecture). So if you want to give a quick check, copy the libelf.so.0 file to /usr/lib or /usr/lib64 and see if that helps.
OpenFOAM 13 FoamX libelfso0 and Fedora Core 4 crosby OpenFOAM Pre-Processing 23 June 24, 2008 02:01
FoamX libelfso0 nunoinlux OpenFOAM Bugs 6 September 11, 2007 20:13
Ubuntu and finding libelfso0 shaun OpenFOAM Installation 3 April 30, 2007 18:40
Canbt fix libelfso0 proble clo OpenFOAM Installation 3 January 10, 2007 04:17
Sshd amp libelfso0 on gentoo box alfreed OpenFOAM Installation 2 June 15, 2006 10:05
