Installation problems
Old   April 6, 2006, 11:08
Default Hi, I'm installing OpenFOAM f
Shelley Nation
shellbell1999 is on a distinguished road
I'm installing OpenFOAM for my boss and this is my first time using linux and I am quite confused. So far I have downloaded all the files from the website and have decompressed them into the correct folders. When I tried to decompress the gcc file I got this error:
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
I also got that when I tried to decompress the java file. The paraview file decompressed fine. So I tried to keep going and just see what would happen. I am pretty sure I sourced the /.bashrc file correctly. I added this at the end of that file:
source /home/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
Then when I tried to update the environment variables by running the /.bashrc file it gives me this:
/root/.OpenFOAM-1.3/bashrc: cannot find FOAM installation
Again I just kept going with the instructions to see what would happen but when I ran the foamInstallationTest I got this:
Checking basic setup...
Shell: bash
Host: sentra
OS: Linux version 2.6.5-1.358
User: root
User_config: /root/.bashrc
FATAL ERROR: /root/.OpenFOAM-1.3/bashrc does not appear to be sourced from:
/root/.bashrc
You need the following at the end of your /root/.bashrc file:
. /root/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
or equivalent depending on the location of the OpenFOAM installation.
FATAL ERROR Cannot find FOAM installation at: /root/OpenFOAM
Set correct path to installation 'WM_PROJECT_INST_DIR' in /root/.foam2.3/bashrc
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /root/OpenFOAM no yes
$WM_PROJECT_USER_DIR --------- env variable not set --------- no
$FOAM_JOB_DIR --------- env variable not set --------- yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR --------- env variable not set --------- yes
$FOAM_USER_APPBIN --------- env variable not set --------- no
$FOAM_APPBIN --------- env variable not set --------- yes
$WM_DIR --------- env variable not set --------- yes
$FOAMX_PATH --------- env variable not set --------- yes
$CEI_HOME --------- env variable not set --------- no
$JAVA_PATH --------- env variable not set --------- no
$MICO_ARCH_PATH --------- env variable not set --------- yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN --------- env variable not set --------- yes
$FOAM_USER_LIBBIN --------- env variable not set --------- no
Software versions
Software Version Location
gcc 3.3.3
WARNING: Conflicting installations:
foam settings: /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java *** not installed ***
gzip 1.3.3 /bin/gzip
tar 1.3.3 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_sentra Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
The system test has evoked 2 fatal error(s).
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
If anyone could help me on any of these problems I would greatly appreciate it.
Thanks.
shellbell1999 is offline   Reply With Quote
Old   April 6, 2006, 11:21
Default Hi Shelley, Something seem t
Rasmus Hemph
hemph is on a distinguished road
Hi Shelley,
Something seem to have gone wrong with your download of gcc, you should try downloading it and paraFoam again.
Also it appears that you did not source your .bashrc-file correctly. After you add
. $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
to the bottom of your .bashrc-file, you want to open a new terminal window for the changes to take effect. The README file in OpenFOAM-1.3-directory should help you along the way.
hemph is offline   Reply With Quote
Old   April 6, 2006, 11:32
Default Sorry, you should not need to
Rasmus Hemph
Sorry, you should not need to download paraview again! just the java-archive which didn't work.
Old   April 6, 2006, 11:59
Default Thank you for your help, and w
Shelley Nation
Thank you for your help, and while that did fix the problems I was having with the gcc and java files, I'm still getting the cannot find FOAM installation error after I try to run the .bashrc file. I tried to close the terminal window and then open a new one, but it still gives me the same error. When I run the foamInstallationTest and it says:
would that fix it? If so, how do I do this?
Thanks
Old   April 6, 2006, 12:14
Default The installation expects OpenF
Rasmus Hemph
The installation expects OpenFOAM-1.3 to be installed in a directory named OpenFOAM for the current user, which in your case happens to be root.
For some reason it does not find the files in that directory. Did you unpack the files as described in http://www.opencfd.co.uk/openfoam/linux.html?
Old   April 6, 2006, 12:22
Default Yes I did, I put source pack a
Shelley Nation
Yes I did, I put source pack and 2 binary packs in
/home/OpenFOAM
and the 3 other binary packs in
/home/OpenFOAM/linux
which can be seen below:
[root@sentra OpenFOAM]# ls
linux OpenFOAM-1.3.linuxGcc4DPOpt.gtgz
OpenFOAM-1.3 OpenFOAM-1.3.linuxGcc4SPOpt.gtgz
OpenFOAM-1.3.General.gtgz
[root@sentra OpenFOAM]# cd /home/OpenFOAM/linux
[root@sentra linux]# ls
gcc-4.1.0 j2sdk1.4.2_05 paraview-2.4.2
gcc-4.1.0.linux.tgz j2sdk1.4.2_05.linux.tgz paraview-2.4.2.linux.tgz
Thank you for helping me with this
Old   April 6, 2006, 12:35
Default ok, so far so good. You need t
Rasmus Hemph
ok, so far so good. You need to unzip and unpack the files as well. In the OpenFOAM directory,
type
tar -zxvf OpenFOAM-1.3.linuxGcc4DPOpt.gtgz
tar -zxvf OpenFOAM-1.3.General.gtgz
In the linux subdirectory, you need to do the same thing, but it looks like you already unpacked those files?
Old   April 6, 2006, 12:56
Default before I used the command tar
Shelley Nation
before I used the command tar xvf <filename>. I tried using that command for all the files again. Then I closed the terminal and tried to call the .bashrc file again and I'm still getting the foam installation error.
Old   April 6, 2006, 13:12
Default I see now, you installed into
Rasmus Hemph
I see now, you installed into /home/OpenFOAM, but the installation is expecting you to install in your home directory which is /root in this case. You need to move the files to your home directory. Type
mv /home/OpenFOAM /root
in a terminal and then try again.
Old   April 6, 2006, 13:29
Default Good call! Once I did that I w
Shelley Nation
Good call! Once I did that I went and changed the source call in the .bashrc file and now it all checks out. Thank you so much!
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
Installation problems ianz8802 OpenFOAM Installation 37 January 30, 2009 13:20
Installation Problems honcho OpenFOAM Installation 0 January 14, 2008 10:48
Problems on 64bit Installation Dietmar Schmidt Siemens 4 April 18, 2007 06:36
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 04:16
