OpenFOAM in a Linux Cluster
Old   August 19, 2005, 12:54
Default Hi, Are there any links on se
Md. Ashfaque-Ur-Rahman
gedanken is on a distinguished road
Are there any links on setting up OpenFOAM in a Linux cluster?
If not please tell me some initial guidelines to setup one with these:
1 x 16 Port 100 Mbps Switch
16 x 2.8 Ghz P4 Fedora 3 Linux machines with 100MBps NIC
I've downloaded and ran FOAM in a single PC.
Many thanks in Advance
Ashfaque
gedanken is offline   Reply With Quote
Old   August 25, 2005, 13:32
Default Install it using the same step
Maka Mohu
maka is on a distinguished road
Install it using the same steps you did on a single PC but this time in your account folder on the cluster.
if the cluster is working fine once you log on to the main node, you can ssh to any processor on the cluster.
To run in parallel:
You may read the user guide 2.3.10.
Regards,
Maka
maka is offline   Reply With Quote
HPC on a Linux cluster Jihwan Siemens 2 November 22, 2005 10:17
cluster on Linux Ivan Siemens 2 December 3, 2004 11:03
LINUX CLUSTER co2 FLUENT 1 April 24, 2004 04:30
linux cluster Johan Carlsson Siemens 6 July 4, 2003 12:02
linux cluster Johan Carlsson Main CFD Forum 2 June 21, 2003 07:14
