Uninstalling Qt4.4.3
Old   April 12, 2009, 17:24
Default Uninstalling Qt4.4.3
Paul Z.
Paul12345 is on a distinguished road
Hi All,
I, like so many others, am having problems with OpenFOAM. I installed it and everything seems fine until the last few steps that are related to ParaView.
I am running Ubuntu 8.10, which comes with Qt4.4.3. I downloaded Qt4.3.5 and it is located in /usr/local/Trolltech/Qt-4.3.5.
Although some have said that they were able to run Paraview using newer versions of Qt, I believe my problem is related to my Qt version.
How do I get OF1.5 to use the older version of Qt found in the above directory instead of the newer version? Is there a way to tell it to do that? I tried finding a thread explaining how to uninstall Qt but I could not find anything.
Is there a quick way to find all the files associated with Qt and to get rid of them? Or alternatively, is it possible to tell OF to use this older version of Qt?
Thank you in advance!
Paul
Paul12345 is offline   Reply With Quote
Old   April 14, 2009, 04:06
Default Compile your own QT
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Paul,
I'm not sure that I fully understood your question, but as a general information, you can compile and run paraview using your system installation of QT library or your own installed one.
Check this excellent explanation: http://www.cfd-online.com/Forums/ope...tml#post207193
Regards,
Dragos
dmoroian is offline   Reply With Quote
uninstalling fluent 6.0 in win XP yf FLUENT 6 November 29, 2004 00:51
