Kubuntu 8.10: paraFoam differences between 32 and 64 bit. Can you help me?
Old   June 28, 2009, 07:26
Default Kubuntu 8.10: paraFoam differences between 32 and 64 bit. Can you help me?
Xwang is on a distinguished road
I've two computer both with Kubuntu 8.10.
One has a 64bit OS, theother 32bit.
On the 64bit machine paraFoam works without any problem, while on the 32 bit machine it works only if I use foamToVTK.
qmake --version is:
QMake version 2.01a
Using Qt version 4.4.3 in /usr/lib
on both machines.
What can I do to have paraFoam working on the 32 bit machine?
I've installed on the 32bit only to see if I've problem with openFoam if I upgrade to kubuntu 9.04, but I wonder if the difference between the two version can cause misleading results.
Xwang
Xwang is offline   Reply With Quote
