Is it better to create a user for openFOAM?
Old   June 25, 2009, 18:06
Default Is it better to create a user for openFOAM?
Xwang is on a distinguished road
Hi, I've tried to install openFOAM using my user, but I've see that it changes the default gcc compiler to the one shipped with openFOAM. So I'm wondering if it is better to create a user specifically for OF15 so that to mantain the base system as shipped by the distro. Then to use OF and paraview I've just to log as the newuser using ssh -X, is it correct? Xwang
Xwang is offline   Reply With Quote
Old   June 26, 2009, 05:25
Gunnar Werte
gunnar is on a distinguished road
No, in my opinion it is better to eat vegetables.
gunnar is offline   Reply With Quote
Old   June 26, 2009, 05:30
Rishi .
hellorishi is on a distinguished road
You can use the same user for OF and other requirements.
It is all about sourcing the correct variables. If you remove/or better hide the following line from your .bachrc file, you can use default gcc compiler of your Linux (not OF)
. $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/bashrc
AND
You can also create a seperate user for OF (and ParaView) and then just log into that system, by rebooting or logging off current user.
hellorishi is offline   Reply With Quote
Old   June 26, 2009, 08:47
Michael Roth
roth is on a distinguished road
Or you can just use your system compiler by making a switch in your $WM_PROJECT_DIR/etc/settings.sh:
# Select compiler installation
# compilerInstall = OpenFOAM | System
compilerInstall=System
I find using the system compiler is the path of least resistance.
Michael
roth is offline   Reply With Quote
Old   June 26, 2009, 13:58
Michael
The fact that system compiler is 4.3.2 instead of openfoam 4.3.1, can create problems? Xwang
Old   June 27, 2009, 04:00
I've set in etc/settings.sh:
WM_COMPILER_INST=System
but if I run the foamInstallationTest I obtain:
./foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               pro5av
OS:                 Linux version 2.6.27-14-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/andreak/OpenFOAM                   yes       yes
$WM_PROJECT_USER_DIR /home/andreak/OpenFOAM/andreak-1.5       yes       no
$WM_THIRD_PARTY_DIR  /home/andreak/OpenFOAM/ThirdParty        yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/andreak/OpenFOAM/OpenFOAM-1.5      yes  yes  yes
$FOAM_APPBIN         ...1.5/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_USER_APPBIN    ...1.5/applications/bin/linux64GccDPOpt  yes  yes  no
$WM_DIR              .../andreak/OpenFOAM/OpenFOAM-1.5/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_USER_LIBBIN    ...FOAM/andreak-1.5/lib/linux64GccDPOpt  yes  yes  no
$MPI_ARCH_PATH       ...nmpi-1.2.6/platforms/linux64GccDPOpt  yes  yes  yes
Third party software
Software Version   Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
         Supplied version: 4.3.1
         User version    : ../src/configure
4.3.2
         Minimum required: 4.2.0
gcc      ...figure
WARNING:  Conflicting installations:
          OpenFOAM settings        : /bin/gcc
          current path             : /usr/bin/gcc
          CRITICAL ERROR
gzip     1.3.12    /bin/gzip
tar      1.20      /bin/tar
icoFoam  1.5       .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action                   Result                                       Crit
Pinging_pro5av           Successful                                   yes
Pinging_localHost        Successful                                   yes
Test_rsh:                Unsuccessful_connection_refused*             yes
Test_ssh:                Successful                                   yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
So it seems that I have to change the path of the gcc compiler in OpenFoam (which is wrong).
How can I change it?
Thank you,
Xwang
Old   July 15, 2009, 06:31
Default Solution
A. Rudolf
arudolf is on a distinguished road
You have set the WM_COMPILER_DIR to /usr. You can try that it works by simply setting this variable in your shell and then run foamInstallationTest.
To have the correct setting in all shells, I have added the red lines in $WM_PROJECT_DIR/etc/$settings.sh:
WM_COMPILER_BIN=$WM_COMPILER_DIR/bin
WM_COMPILER_LIB=$WM_COMPILER_DIR/lib$WM_COMPILER_LIB_ARCH:$WM_COMPILER_DIR/lib
System)
export WM_COMPILER_DIR=/usr
esac
arudolf is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
How to create an user defined function? Cagdas FLUENT 1 September 5, 2007 20:02
How to create a user surface on a domain between.. Yuan Liu CFX 2 October 3, 2006 03:24
how to create a user surface in cfx5.7 feng CFX 1 September 20, 2004 17:55
