OpenFOAM Installation Ubuntu 9.04 Problems
Old   July 21, 2009, 12:33
Default OpenFOAM Installation Ubuntu 9.04 Problems
Sumontro
Sumontro is on a distinguished road
I am a new user to Linux and I have no Idea what I am doing wrong.
I followed the installation instructions given, sourcing the bashrc file. But this is the output I got.
sumontro@ubuntu:~$ source $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
Warning in /home/sumontro/OpenFOAM/OpenFOAM-1.5/etc/settings.sh:
Cannot find /home/sumontro/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux installation.
Please install this compiler version or if you wish to use the system compiler,
change the WM_COMPILER_INST setting to 'System' in this file
bash: ./home/sumontro/OpenFOAM/OpenFOAM-1.5/etc/bashrc: No such file or directory
I then changed the compiler installation setting to System, but then this is the output I got.
I don't know why the computer cannot source the bashrc file. It knows that it is there, because I can locate it through find. I would really appreciate some help on this.
Sumontro is offline   Reply With Quote
Old   July 21, 2009, 13:46
akidess's Avatar
Anton Kidess
Did you extract both ThirdParty.General.gtgz and ThirdParty.linuxGcc.gtgz in the proper directories? Does /home/sumontro/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux and is it non-empty?
Also try ". $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc" instead of source.
Old   July 21, 2009, 14:06
Sumontro
I did extract both the ThirdParty.General.gtgz and ThirdParty.linuxGcc.gtgz in the proper directories in $HOME/OpenFOAM and $HOME/OpenFOAM/ThirdParty
$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux is not empty.
Old   July 21, 2009, 14:09
Sumontro
The same message still comes when I source with .
sumontro@ubuntu:~$ . $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
What do I do?
Old   July 21, 2009, 14:19
akidess's Avatar
Anton Kidess
Hm, I think I see the problem. The proper directory would be "/home/sumontro/OpenFOAM/OpenFOAM-1.5/etc/bashrc" without the preceeding dot. Does "echo $HOME" give you "/home/sumontro"? If not, restart the terminal and if the problem is still there, make sure there are no commands in ~/.bashrc that alter $HOME or manually set $HOME to be /home/sumontro.
Old   July 21, 2009, 14:40
Sumontro
yes, when I do echo $HOME, I get /home/sumontro. What else can I do to fix this?
Old   July 21, 2009, 15:01
akidess's Avatar
Anton Kidess
This is odd. I don't see why it would be trying to use ./home if your $HOME variable is correct. You could try sourcing ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc or /home/sumontro/OpenFOAM/OpenFOAM-1.5/etc/bashrc to avoid using the environment variable.
If that doesn't work you might want to try from scratch.
Old   July 21, 2009, 15:44
Sumontro
ok, I fixed the source problem. It seems I was putting that last line into the wrong bashrc file. However, when I source $HOME/.bashrc, nothing happens. When I run the installation script, it gives me two critical errors,
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../src/configure
4.3.3
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam
OpenFOAM settings : /home/sumontro/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
How do I fix this?
Old   July 21, 2009, 21:40
Ramesh Yapalparvi
yapalparvi is on a distinguished road
Just follow the same procedure as in given in the readme file. Create a driectory OpenFOAm and download all ur tar flies. make sure you are downloading the correct files for the platform. Extract everything in the same directory. Set your path in /.bashrc and add the same line as given in the readme file. I would recommend you close the terminal and open a new one. Then use . $HOME/.bashrc command to set the paths. then type "which gcc". This should point to the directory where your third party files are included which contains gcc as well. If it doesnt point to the directory then you are doing something wrong and that is why you are getting the error conflicting compilers
yapalparvi is offline   Reply With Quote
openfoam 1.5
[Commercial meshers] Boundary condition problems (OpenFOAM) Milos OpenFOAM Meshing & Mesh Conversion 13 October 13, 2016 19:58
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
MPI error on Ubuntu 9.04 denner OpenFOAM Running, Solving & CFD 3 June 13, 2009 13:38
[General] OpenFoam - problems MateuszZb ParaView 8 July 21, 2008 16:16
installation problems on upgrade from win 3.26 to mic Siemens 5 June 20, 2007 09:40
