OpenFOAM-1.5-dev compilation: OSspecific trouble |
September 23, 2009, 10:58 |
Gijsbert Wierink
Rep Power: 18 |
Dear all,
I have compiled a snap shot of OpenFOAM-1.5-dev on my laptop (Fedora 10 x86_64) and it works beautifully. Now I am compiling it also on my desktop (Fedora 11 x86_64) and want to use the svn version. When I compile the svn version of dev on my desktop I get stuck at compiling OSspecific in src. Anyhting from sifFpe.o and beyond is not created. I could not find out how and why, so I copied the missing .o files from the same dir in my laptop. Not very pretty, I know, but it seems to work . I ran into the same problem in meshTools and had to copy surfaceFeatures.o there as well. After rerunning Allwmake all seems to work. Does anyone have an idea how to fix this in a more elegant way? Thanks in advance! Regards, Gijs PS Some more info: I used my system compiler (gcc-4.4.1) and when I switch to OpenFOAM's compilers things like blockMesh stop working (problem with libstdc++.so.6) The first error message (for OSspecific) was: Code:
[gijsbert@mintek src]$ wmake libo OSspecific/$WM_OS SOURCE=signals/sigFpe.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1435 -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sigFpe.o SOURCE=signals/sigInt.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1435 -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sigInt.o In file included from /usr/include/stdio.h:909, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/cstdio:50, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/bits/char_traits.h:48, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/string:47, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/string.H:51, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/messageStream.H:50, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/error.H:52, from signals/sigFpe.C:27: /usr/include/bits/stdio.h: In function ‘__ssize_t getline(char**, size_t*, FILE*)’: /usr/include/bits/stdio.h:118: error: ‘__getdelim’ was not declared in this scope In file included from /usr/include/stdio.h:909, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/cstdio:50, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/bits/char_traits.h:48, from /home/gijsbert/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/string:47, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/string.H:51, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/messageStream.H:50, from /home/gijsbert/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/error.H:52, from signals/sigInt.C:27: /usr/include/bits/stdio.h: In function ‘__ssize_t getline(char**, size_t*, FILE*)’: /usr/include/bits/stdio.h:118: error: ‘__getdelim’ was not declared in this scope make: *** [Make/linux64GccDPOpt/sigFpe.o] Error 1 make: *** Waiting for unfinished jobs.... make: *** [Make/linux64GccDPOpt/sigInt.o] Error 1 Code:
[gijsbert@mintek src]$ wmake libso meshTools triSurface/surfaceFeatures/surfaceFeatures.C:770: error: conflicting declaration ‘Foam::octreeDataPoint samples’ triSurface/surfaceFeatures/surfaceFeatures.C:769: error: ‘samples’ has a previous declaration as ‘Foam::treeBoundBox samples’ triSurface/surfaceFeatures/surfaceFeatures.C: In member function ‘Foam::Map<int> Foam::surfaceFeatures::nearestSamples(const Foam::labelList&, const Foam::pointField&, const Foam::scalarField&, const Foam::scalarField&, Foam::scalar) const’: triSurface/surfaceFeatures/surfaceFeatures.C:871: error: conflicting declaration ‘Foam::octreeDataPoint samples’ triSurface/surfaceFeatures/surfaceFeatures.C:870: error: ‘samples’ has a previous declaration as ‘Foam::treeBoundBox samples’ make: *** [Make/linux64GccDPOpt/surfaceFeatures.o] Error 1 make: *** Waiting for unfinished jobs.... |
September 24, 2009, 09:35 |
Solved
Gijsbert Wierink
Rep Power: 18 |
Dear all,
There was some problem with gcc, because when I actually compiled gcc into ThirdParty the problem was solved. But for that I needed some flags and to install mpfr. So here is the recipe for the record.
k Omega SST SAS for OpenFOAM 1.5??? | barath.ezhilan | OpenFOAM Running, Solving & CFD | 3 | June 2, 2010 07:41 |
OpenFOAM 1.5 installation on OpenSUSE 11.0 | bigphil | OpenFOAM Installation | 16 | April 29, 2009 06:28 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
