December 19, 2009, 16:29 |
Bug in path variable $FOAM_RUN
James Baker
Rep Power: 16 |
I have installed OpenFOAM 1.6 on Ubuntu 9.10 and moved the install to a different directory. I updated the path variable and everything works except when I went to $FOAM_RUN, it is still trying to go back to where it "should" be installed. I checked my enviornmental variables by typing env in the console and FOAM_RUN, FOAM_USER_APPBIN, WM_PROJECT_USER_DIR are all point to the wrong directory. The rest are correct. Any help is appreciated.
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
