paraview 3.10.1 compiling error (1.6-ext)
Old   September 27, 2011, 10:19
Default paraview 3.10.1 compiling error (1.6-ext)
Vesselin Krastev
vkrastev is on a distinguished road
Hi everyone,
has anybody succeeded in solving the following compiling error (it comes at the end of the Allmake script run into the ThirdParty directory of OpenFOAM-1.6-EXT)?
CMake Error at /home/chuang/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.10.1/CMake/BundleUtilities.cmake:627 (message):
error: fixup_bundle: not a valid bundle
Call Stack (most recent call first):
Applications/ParaView/cmake_install.cmake:80 (fixup_bundle)
Applications/cmake_install.cmake:37 (INCLUDE)
cmake_install.cmake:118 (INCLUDE)
Searching in the web I've found this post:
http://comments.gmane.org/gmane.comp...iew.user/11668
I've tried to turn off this option (it's in the /rpmBuild/BUILD/ParaView-3.10.1/CMake/ParaViewCommon.cmake file), but it seems like it is again turned on by some kind of default setting, because after turned it off the compilation stops again at the same point and opening back the ParaViewCommon.cmake file it appears again as the default version...
Any help will be appreciated
V.
PS-Has anybody succeeded AT ALL in compiling paraview 3.10.1 inside the 1.6-ext release?????
vkrastev is offline   Reply With Quote
Old   September 28, 2011, 07:15
Question
Vesselin Krastev
Do I have to understand that all the 1.6-ext users do not use the ThirdParty-compiled paraview 3.10.1 for postprocessing?
V.
Old   September 29, 2011, 05:07
Elvis
elvis will become famous soon enough
looks like most of the users dealing with Extend-Version go to "extend-project"
http://www.extend-project.de/user-fo...n-openfoam#286
elvis is offline   Reply With Quote
Old   September 29, 2011, 05:45
Vesselin Krastev
Originally Posted by elvis View Post
Thanks for the reply, but unfortunately the discussion pointed by your link doesn't solve my problem. Maybe I could start a tread over there and see what happens...
Regards
V.
Old   September 30, 2011, 11:42
Jason Eason
JulytoNovember is on a distinguished road
I had the same problem, I switched to paraview-3.8.1 and now paraview works. Find your paraview.spec file its in the ThirdParty/rpmBuild/SPECS folder. Rename the file to Paraview-3.8.1, and also change all the 3.10.1 to 3.8.1 inside the file. This should work, I had to adjust and few things afterward, but they were not a big deal. Any further problem post here all I will see if I can help.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   September 30, 2011, 11:48
Vesselin Krastev
Thanks for your hints, I think I will give them a try (and let you know what happens).
V.
Old   October 10, 2011, 05:01
Vesselin Krastev
I switched to paraview 3.8.1 and now it works! Thanks once again!
V.
Old   October 28, 2011, 03:17
Default fixed bundle problem solution
P.A.
blaise is on a distinguished road
I managed to fix the problem with the fixup_bundle issue following another post (I can't remember the link).
So: In the ParaView3.10.1 SPECS file (in ThirdParty/rpmbuild/SPECS) I added/altered some lines after
echo " _mesaLibPath : %{_mesaLibPath}"
echo " _pythonLibPath : %{_pythonLibPath}"
echo ""
set -x
# For Python and MPI Support (by the way, you need this to be added explicitly to
# compile PYTHON shell and parallel support into ParaView. The entries earlier in this file
# are not sufficient in my case)
addCMakeVariable PARAVIEW_ENABLE_PYTHON:BOOL=ON
addCMakeVariable PARAVIEW_USE_MPI:BOOL=ON
# >>> Here comes the fixup_bundle solution
addCMakeVariable PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES:BOOL=OFF
# start with these general settings
addCMakeVariable VTK_USE_TK:BOOL=OFF
# >>> I think one this is necessary too.
addCMakeVariable BUILD_SHARED_LIBS:BOOL=OFF VTK_USE_RPATH:BOOL=OFF
#addCMakeVariable BUILD_SHARED_LIBS:BOOL=ON VTK_USE_RPATH:BOOL=OFF
addCMakeVariable CMAKE_BUILD_TYPE:STRING=Release
# >>> And in case you have some trouble with MESA related errors you can comment Hrvoje's additional
# lines, like this:
# HJ, 9/Aug/2011
#addCMakeVariable OPENGL_gl_LIBRARY:STRING=
# HJ, 9/Aug/2011
#addCMakeVariable VTK_USE_OPENGL_LIBRARY:BOOL=ON
At least this is the way I finally got OF-1.6-ext with ParaView3.10.1 running on a CentOS 5.3 (Kernel 2.6.18-128.4.1.el5) machine.
Hope that helps!
Cheers,
Pascal.
blaise is offline   Reply With Quote
[OpenFOAM] Segmentation fault with paraview 3.10.1 aot ParaView 5 June 5, 2023 01:32
error install Paraview 3.10.1 qt preibie OpenFOAM 6 August 24, 2011 16:11
OF-1.6-ext enable MPI in paraview compiling pcaron OpenFOAM Installation 2 March 7, 2011 17:58
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
