Flex and readSTLASCIIL
Old   March 8, 2009, 11:02
Default Good morning, I'm experienc
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Good morning,
I'm experiencing some issues when compiling 1.5.x on Linux using gcc-4.3.1 (or gcc-4.3) with flex 2.5.35 :
triSurface/interfaces/STL/readSTLASCII.L:60: error: no 'int yyFlexLexer::yywrap()' member function declared in class 'yyFlexLexer'
lex.yy.cc: In member function 'int STLLexer::lex()':
lex.yy.cc:5526: error: 'yy_buffer_stack' was not declared in this scope
lex.yy.cc:5526: error: 'yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:5527: error: 'yyensure_buffer_stack' was not declared in this scope
lex.yy.cc:5549: warning: use of old-style cast
lex.yy.cc:5565: warning: use of old-style cast
lex.yy.cc:5779: warning: use of old-style cast
lex.yy.cc:5785: error: 'yy_buffer_stack' was not declared in this scope
lex.yy.cc:5785: error: 'yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:5808: error: 'yy_buffer_stack' was not declared in this scope
lex.yy.cc:5808: error: 'yy_buffer_stack_top' was not declared in this scope
I had similar issues with the old flex version 2.5.4 and that is why I ent with flex 2.5.35 / anybody has an idea ? I found
similar posts but nothing seems to help here. It looks that readSTLASCII.L already included the modifications proposed.
Best regards,
PO
podallaire is offline   Reply With Quote
Old   May 27, 2010, 12:22
kshitij neroorkar
kdneroorkar is on a distinguished road
Hi
I am also getting this same error while compiling OF1.5-dev. Were you able to find a solution to this ?
Regards
Kshitij
kdneroorkar is offline   Reply With Quote
Old   June 1, 2010, 17:00
Default hi
kshitij neroorkar
I think I figured it out. This happens when you have a local install of flex
you need to modify the options file in triSurface/Make to point to the location where FlexLexer.h file is stored. The function yywrap() is defined in this header file.
Kshitij
What is the difference between flex and foamFlex allenzhao OpenFOAM Installation 1 August 14, 2008 17:17
OpenFOAM 14 problem with file readSTLASCIIL mbeaudoin OpenFOAM Bugs 2 April 13, 2007 21:09
Flex vs foamFlex lel OpenFOAM Installation 2 October 11, 2006 06:23
Flex License Borrowing Henry Oxted Main CFD Forum 5 March 23, 2005 16:59
vig-o-flex lipovetzky leonid Main CFD Forum 0 October 6, 1998 10:48
